When $T$ is any linear operator acting on a vector space $V$, and $n$ is a natural number, $T^n$ means $T$ applied $n$ times (composition) and that is also a linear operator. That is clear.
When $T$ is a nonzero linear operator acting on a vector space $V$, then $T^0$ is the identity operator $T^0 = I$. But I think that should also be true (true by definition), when $T$ is the zero operator i.e. the operator which sends all vectors to the zero vector.
Why? Because $T^0$ means that we are not applying any operator. So it makes sense to say: OK, all vectors stay unchanged when "applying" $T^0$ even when $T$ is the zero operator. I say "applying" because we're not actually applying anything.
Is that indeed so?
I am asking because this kind of disagrees with what we have for real numbers where $0^0$ is usually left undefined.
EDIT:
What's the context of this question? I was reading a proof for the uniqueness of the Jordan Normal Form. There this expression comes up $2d(\phi^p) - d(\phi^{p-1}) - d(\phi^{p+1})$, where $p$ is a positive integer, and $d$ is the defect of the linear operator in the brackets. The proof is very nice but convoluted and eventually it boils down to proving the uniqueness for a special linear operator which has only $0$ as a characteristic root (as an eigenvalue). So I had some doubts what happens exactly with the expression $\phi^{p-1}$ when $p = 1$, and if we need to put some restrictions on the linear operator $\phi$.
