$(ac+bd)^2+(ad-bc)^2=(a^2+b^2)(c^2+d^2)$
Solutions in the answers.
Edit) Since this question is closed, I'll add more contexts for this question.
This identity is called "Brahmagupta-Fibonacci identity", which the comment says.
This identity has a special feature, that the form of the expression maintains from LHS to RHS.
Also, for addition, we can expanse this identity to: $$ (a^2+nb^2)(c^2+nd^2)=(ac\pm nbd)^2+n(ad\mp bc)^2. $$ or: $$ X=xz-Cyw, Y=axw+a'yz+BYw. \\ (ax^2+Bxy+a'Cy^2)(a'z^2+Bzw+aCw^2)=aa'X^2+BXY+CY^2 $$ , from the answer of @Will Jagy.
This can be proved by various solutions, for example, just multiplying out this identity, or with trigonometric functions, or with the imaginary number "$i$".
I want you to prove this identity with more solutions.
RDK
  • 2,623
  • 30
6 Answers6
Simpler Solution.
\begin{align} & (ac+bd)^2+(ad-bc)^2 \\ = \; & (ac)^2+2abcd+(bd)^2+(ad)^2-2abcd+(bc)^2 \\ = \; & a^2c^2+b^2d^2+a^2d^2+b^2c^2 \\ = \; & (a^2+b^2)(c^2+d^2) \end{align}
RDK
  • 2,623
  • 30
    This is nice! I think this solution is the simplest solution for this problem. – RDK Jun 25 '22 at 23:37
Here is Gauss composition, using Dirichlet's method. This version is in David A. Cox, Primes of the Form $x^2 + n y^2,$ from the proof of Proposition 3.8. In the first edition, this is page 49(but has a typing error, corrected in the second edition).
Everything is integers. We are given $a, a', B,C$ and integer variables $x,y,z,w.$
By defining $$ X = xz - Cyw $$ $$Y = axw + a' yz + B yw,$$ we find $$ \left(ax^2 + Bxy + a'Cy^2 \right) \left(a'z^2 + Bzw+aCw^2 \right) = aa'X^2 + BXY + C Y^2 $$
Your version has $a=a'=C=1$ and $B=0$
Will Jagy
  • 139,541
    This is interesting... It's an expansion of the one I have questioned. – RDK Jun 25 '22 at 23:34
  • Let me ask one thing. Is it trivial to show that $(ax^2+Bxy+a'Cy^2)(a'z^2+Bzw+aCw^2)=aa'X^2+BXY+CY^2$ by just multiplying out this one? – RDK Jun 27 '22 at 14:19
    @rdk yes, completely straightforward. I suggest you set aside a page or two in a notebook and confirm the thing by hand. Oh, Cox wanted to emphasize the similar roles of $a$ and $a'.$ One could easily pick other letters for all the coefficients... Good practice, and it should help the thing fit better in your mind – Will Jagy Jun 27 '22 at 17:31
There are two possible factorizations. Here are both of them.
$\begin{array}\\ (a^2+b^2)(c^2+d^2) &=a^2c^2+a^2d^2+b^2c^2+b^2d^2\\ &=a^2c^2+b^2d^2+a^2d^2+b^2c^2\\ &=a^2c^2+b^2d^2\pm2a^2b^2c^2d^2+a^2d^2+b^2c^2\mp2a^2b^2c^2d^2\\ &=(ac\pm bd)^2+(ad\mp bc)^2 \qquad\text{The two signs are different}\\ \end{array} $
marty cohen
  • 107,799
The identity is trivially satisfied if $\,a=b=0\,$ or $\,c=d=0\,$. Otherwise $\,a^2+b^2 \ne 0\,$ and $\,\left(\frac{a}{\sqrt{a^2+b^2}}\right)^2 + \left(\frac{b}{\sqrt{a^2+b^2}}\right)^2 = 1\,$, so there exists an angle $\,\alpha\,$ such that $\,\frac{a}{\sqrt{a^2+b^2}} = \sin \alpha\,$, $\,\frac{b}{\sqrt{a^2+b^2}} = \cos \alpha\,$. Similarly, define $\,\gamma\,$ such that $\,\frac{c}{\sqrt{c^2+d^2}} = \sin \gamma\,$ and $\,\frac{d}{\sqrt{c^2+d^2}} = \cos \gamma\,$.
After dividing by $\,(a^2+b^2)(c^2+d^2) \ne 0\,$, the identity can then be written as:
$$ (\sin\alpha\sin\gamma \pm \cos\alpha\cos\gamma)^2 + (\sin\alpha\cos\gamma \mp \cos\alpha\sin\gamma)^2 = 1 \\ \iff\quad \cos^2 (\alpha \mp \gamma) + \sin^2 (\alpha \mp \gamma) = 1 \quad\quad $$
dxiv
  • 76,497
\begin{align} & (a^2+b^2)(c^2+d^2) \\ = \; & \Big(a^2-(-b^2)\Big)\Big(c^2+(-d^2)\Big) \\ = \; & \Big(a^2-(ib)^2\Big)\Big(c^2-(id)^2\Big) \\ = \; & (a+ib)(a-ib)(c+id)(c-id) \\ = \; & (a+ib)(c-id)(a-ib)(c+id) \\ = \; & \Big(ac+i(bc-ad)+bd\Big)\Big(ac-i(bc-ad)+bd\Big) \\ = \; & \Big((ac+bd)+i(bc-ad)\Big)\Big((ac+bd)-i(bc-ad)\Big) \\ = \; & (ac+bd)^2-\Big(i(bc-ad)\Big)^2 \\ = \; & (ac+bd)^2+(bc-ad)^2 \end{align}
RDK
  • 2,623
  • 30
    Same, but shorter: $;\big|(a+ib)(c-id)\big|^2 = \big|(a+ib)\big|^2;\big|(c-id)\big|^2,$. – dxiv Jun 25 '22 at 03:55
\begin{align}& (a^2+b^2)(c^2+d^2) \\= \; & (ac)^2+(bc)^2+(ad)^2+(bd)^2 \\= \; & \Big((ac)^2+(bd)^2\Big)+\Big((ad)^2+(bc)^2\Big) \\= \; & \Big((ac)^2+2(ac)(bd)+(bd)^2\Big)+\Big((ad)^2-2(ad)(bc)+(bc)^2\Big) \\= \; & (ac+bd)^2+(ad-bc)^2\end{align}
RDK
  • 2,623
  • 30
