14
Suppose that a sequence $\{a_n\}_{n=1}^\infty$ satisfies $a_1=1$ and $$a_{n+1}=a_n-\frac13a_n^2,\qquad n=1,2,3,\cdots.$$ Which of the following is true?
(A) $2<100a_{100}<\frac52$
(B) $\frac52<100a_{100}<3$
(C) $3<100a_{100}<\frac72$
(D) $\frac72<100a_{100}<4$
This problem comes from my sister's final exam (she is in high school). I have a solution, but my solution is unsatisfactory since it requires some rather complicated computation, which seems impossible to finish during an exam.
My solution. Note that the recurrence relation can be rewritten as $$\frac1{a_{n+1}}=\frac1{a_n}+\frac1{3-a_n},\qquad n=1,2,3,\cdots.$$ Therefore, $$\frac1{a_{100}}=1+\sum_{n=1}^{99}\frac1{3-a_n}.$$ It follows from the original recurrence relation that $a_n$ is decresing and thus $a_n\leq 1$. Using $\frac1{3-a_n}\geq \frac13$, we have $$\frac1{a_{100}}\geq 1+\frac{99}3=\frac{102}3,$$which implies that $100a_{100}\leq \frac{300}{102}<3$. Hence (C) and (D) are excluded. My gut told me that (B) should be the right answer, since $a_n$ will decreasing to $0$ (an exercise for those who are just learning the concept of limits,) in which case $\frac1{3-a_n}$ is almost $\frac13$. Let's check the correctness of (B). After some calculations we have $$a_1=1,\qquad a_2=\frac23,\qquad a_3=\frac{14}{27},\qquad a_4=\frac{67\times 14}{27^2\times 3}=\frac{938}{2187}.$$ Since $a_n\leq a_4$ for $n\geq 4$, we have $$\frac1{a_{100}}\leq 1+\frac12+\frac37+\frac1{3-\frac{14}{27}}+\frac1{3-\frac{938}{2187}}\times 96\approx 39.66<40,$$ where I turned to a caculator. Therefore, $100a_{100}>\frac52$. Note: I tried to use $a_3$ rather than $a_4$, which was easier to compute, but it turned out that using only $a_3$ was not enough to get the desired bound.
My question. Is there any other methods to get the upper bound of $1/a_{100}$? I want a method involving not so many caclulations. At least they can be completed in an exam in which calculators are not allowed.
Feng
  • 13,705
This is pretty similar to a famous exercise about the rate of convergence of the sequence defined by $a_{n+1}=\sin(a_n)$. In your case it is pretty simple to notice that $\{a_n\}$ is positive and decreasing, hence convergent to zero, and by setting $b_n=1/a_n$ (as you cleverly did) we have
$$ b_{n+1} = b_n + \frac{b_n}{3b_n-1}= b_n+\frac{1}{3}+\frac{1}{9b_n-3}\tag{1}$$ where $$ b_{n+1} \geq b_n + \frac{1}{3}$$ implies $$ b_n \geq \frac{n+2}{3} \tag{2}$$ and $a_{100}\leq \frac{3}{102}$, which only leaves options $(A)$ and $(B)$. At this point one might guess that $(2)$ is pretty tight, hence $100 a_{100}$ is less than $3$ but pretty close to $3$ (option $\mathbf{(B)}$). Proving this requires a lower bound for $a_n$, i.e. an upper bound for $b_n$, which we can obtain by plugging $(2)$ back into $(1)$ (bootstrapping): $$ b_{n+1} \leq b_n + \frac{1}{3} + \frac{1}{3}\cdot \frac{1}{n+1} \tag{3}$$ leads to $$ b_n \leq \frac{n+H_n+1}{3} \tag{4}$$ hence $100 a_{100}\geq \frac{300}{101+H_{100}}\geq 2.8 $ and $\mathbf{(B)}$ actually is the correct answer.
An accurate approximation of $H_n=\sum_{k=1}^{n}\frac{1}{k}$ comes from $H_n\approx \log(n)+\frac{1}{\sqrt{3}}$.
A more elementary approximation of $H_{100}$ (a worse one, but still effective for our purposes) can be derived without calculators, using just telescopic series and the Cauchy-Schwarz inequality:
$$\begin{eqnarray*} H_{100} = \frac{25}{12}+\sum_{k=5}^{100}\frac{1}{k} \leq \frac{25}{12}+\sum_{k=5}^{100}\frac{1}{\sqrt{k(k-1)}}\leq \frac{25}{12}+\sqrt{\sum_{k=5}^{100}1 \sum_{k=5}^{100}\frac{1}{k(k-1)}}\end{eqnarray*}$$
leads to
$$ H_{100} \leq \frac{25}{12}+\sqrt{96\sum_{k=5}^{100}\left(\frac{1}{k-1}-\frac{1}{k}\right)}=\frac{25}{12}+\sqrt{96\left(\frac{1}{4}-\frac{1}{100}\right)}\leq \frac{25}{12}+\sqrt{24} \leq 7 $$
then to $100\,a_{100} \geq 3-\frac{1}{4}$.
Feng
  • 13,705
Jack D'Aurizio
  • 353,855
  • How do you know that $\frac{300}{101+H_{100}} \ge 2.8$? – jjagmath Jun 19 '22 at 12:45
  • @jjagmath: it is enough to have a decent approximation of $\log(10)$, I added a last line about it. – Jack D'Aurizio Jun 19 '22 at 12:47
  • Thank you for the answer! I would like to estimate $H_{100}$ in the way that $H_{100}\leq 1+\frac12\times6+\frac18\times93=\frac{125}8<19$ if I'm taking an exam. That's enough to make sure the correctness of (B). Yes, $2.8$ is a more accurate approximation! I'll accept this answer after $20$ hours if there is no other one. – Feng Jun 19 '22 at 13:22
  • @Feng: I also added a calculators-free proof of $H_{100}\leq 7$, leading to the slightly worse lower bound $100 a_{100} \geq 3-\frac{1}{4}.$ – Jack D'Aurizio Jun 19 '22 at 13:33
  • @JackD'Aurizio That's soooooo nice! Thank you very much! – Feng Jun 19 '22 at 13:51
Say we have the recurrence
$$a_{n+1} = a_n - \frac{a_n^2}{A},$$ with $a_1<A$. Write $a_n = \frac{A}{ b_n}$ and we get
$$\frac{A}{ b_{n+1}} = \frac{A}{ b_n} - \frac{A^2}{A b_n^2}$$
and so $\frac{1}{b_{n+1}} = \frac{1}{b_n} - \frac{1}{b_n^2}$ or $$b_{n+1}= 1 + \frac{1}{b_n-1}$$
Therefore
$$b_{n+1} = b_1 + n + \sum_{k=1}^n\frac{1}{b_k-1}\ \ (*)$$
From here we get the first estimates
$$b_1 + (n-1) < b_n < b_1 +(n-1) + (n-1) \frac{1}{b_1 -1}$$
We plug this back ( $n\mapsto k$) into the equality $(*)$ and get better estimates
$\bf{Added:}$
Let's see how to proceed with other recurrences. Say we have
$$a_{n+1} = a_n( 1- \frac{a_n^2}{6})$$
(reminiscent of $a_{n+1} = \sin a_n$). We get for the sequence $b_n \colon =\frac{3}{a_n^2}$
$$b_{n+1} = b_n + 1 + \frac{3 b_n-1}{(2 b_n-1)^2}= b_n + 1 + \frac{3}{2}\cdot\frac{1}{2 b_n-1} + \frac{1}{2}\cdot \frac{1}{(2b_n-1)^2}$$
We get $b_n\to \infty$, $b_{n+1}- b_n \to 1$, $\frac{b_n}{n}\to 1$, so asymptotics of $a_n$. But also some effective estimates ( this answer is related, and suggests a general approach).
orangeskid
  • 53,909
    Thanks for your answer! But I think the formula $(*)$ should be $b_{n+1}=b_n+1+\frac1{b_n-1}$. Would you please check it again? – Feng Jun 19 '22 at 15:18
  • @Feng: Yes indeed, thanks! Let me correct it real quick – orangeskid Jun 19 '22 at 16:59
  • @Feng: I clicked on it and it corrected itself.... then I realized you just corrected it... yes, very good, thanks! – orangeskid Jun 20 '22 at 01:21
    This is a very nice answer! Thank you for letting me see a more general picture! -:) – Feng Jun 20 '22 at 01:24
    @Feng: Wouldn't have happened without your question. And Jack D'Aurizio, he really likes the Harmonic numbers. You are very welcome! – orangeskid Jun 20 '22 at 01:28
