I am looking through this proof provided here:
https://math.stackexchange.com/a/78090/1039033
And I don't completely understand the induction process being used in the top voted answer.
Lemma. If $v_1 + v_2 + \cdots + v_k \in W$ and each of the $v_i$ are eigenvectors of $A$ corresponding to distinct eigenvalues, then each of the $v_i$ lie in $W$.
Proof. Proceed by induction. If $k = 1$ there is nothing to prove. Otherwise, let $w = v_1 + \cdots + v_k$, and $\lambda_i$ be the eigenvalue corresponding to $v_i$. Then:
$$Aw - \lambda_1w = (\lambda_2 - \lambda_1)v_2 + \cdots + (\lambda_k - \lambda_1)v_k \in W.$$
By induction hypothesis, $(\lambda_i - \lambda_1)v_i \in W$, and since the eigenvalues $\lambda_i$ are distinct, $v_i \in W$ for $2 \leq i \leq k$, then we also have $v_1 \in W$. $\quad \square$
Arturo Magidin
  • 398,050
No_Bass
  • 67
  • Please do not use images to convey information; here is an explanation why. – Arturo Magidin May 26 '22 at 18:04
  • If $w$ is an eigenvector and $k\neq 0$, then $kw$ is also an eigenvector. Here, $\lambda_j-\lambda_1\neq 0$, so each of the summands on the right hand side is an eigenvector. Thus, you have a sum of $k-1$ eigenvectors of $A$ which lies in $W$, so by the inductio hypothesis each of the $(\lambda_j-\lambda_1)v_i$ are in $W$. Multiplying by $1/(\lambda_j-\lambda_1)$ gives you that $v_2,\ldots,v_k\in W$, and since $v_1+\cdots+v_k$ is also in $W$, so is $v_1$. – Arturo Magidin May 26 '22 at 18:06
Here is a different proof without using induction. However, it requires some knowledge of polynomials. Since $W$ is $A$-invariant, it is also $f(A)$-invariant for any $f\in F[x]$, where $F$ is the base field. In particular, for any $f\in F[x]$, we have $$f(A)v_1+f(A)v_2+\dots +f(A)v_k\in W.$$ Since $Av_i=\lambda_iv_i$, we have $f(A)v_i=f(\lambda_i)v_i$. Thus the above equation says that $$(*)\qquad f(\lambda_1)v_1+f(\lambda_2)v_2+\dots+f(\lambda_k)v_k\in W.$$ Fix an index $i$, we can construct the polynomial $$f(x)=(x-\lambda_1)(x-\lambda_2)\cdots \widehat{(x-\lambda_i)}\cdots(x-\lambda_k)=\prod_{1\le j\le k, j\ne i}(x-\lambda_j).$$ Here $\widehat{(x-\lambda_i)}$ means the term $x-\lambda_i$ is omitted from the product. Notice that $f(\lambda_i)\ne 0$ (since $\lambda_1,\dots,\lambda_k$ are distinct), and $f(\lambda_j)=0$ for any $j\ne i$. Apply this polynomial to the above equation $(*)$, we know that $f(\lambda_i)v_i\in W$. Since $f(\lambda_i)\ne 0$, we get that $v_i\in W$.
Q-Zhang
  • 1,608
