I don't have much knowledge about Differential Topology neither Differential Geometry, but working on this another question about solutions to differential equations, and someone recommend me to research about the Frobenius theorem (differential topology), so I start to read it and going deeper on the Wikipedia pages, but this abstract framework is hard to understand without previous introduction.
But without diving too deep, I found in Wikipedia that for Differential topology as also for Differential geometry, are both defined over Smooth Manifolds, which are explained as "In mathematics, a smooth structure on a manifold allows for an unambiguous notion of smooth function.".
On the mentioned question I am asking about the properties of the solutions of finite duration to differential equations, like the following example: $$\dot{x}=-\text{sgn}(x)\sqrt{|x|},\,x(0)=1\tag{Eq. 1}\label{Eq. 1}$$ admits the finite duration solution: $$x(t)=\frac{1}{4}(2-t)^2\theta(2-t) \tag{Eq. 2}\label{Eq. 2}$$ as is proved in this answer. Here, is easy to see that \eqref{Eq. 2} is not a smooth function, so following the previous definitions it should't be possible to work with this kind of solutions under the framework of Differential Topology/Geometry, which is indeed what I want to figure out, before lost time going deeper into these theories.
- Does Differential Topology/Geometry frameworks only manage to work with smooth solutions to differential equations?
- Does Differential Topology/Geometry frameworks manage to work with analytic solutions to differential equations?
- It is possible for Differential Topology/Geometry frameworks to work with solutions to differential equations that aren't analytic in their whole domains? (like piecewise defined solutions)
- Bonus: It is possible for Differential Topology/Geometry frameworks to work with solutions to differential equations that are of finite duration? Any examples? (see this question for examples of what I mean with solutions of finite duration)
Added later
Recently on another question, a comment leading me for looking for the term finite extinction time, and I found the following paper:
Where is claimed the solutions achieved a finite extinction time, and it is used a language similar to the used on DT/DG.... unfortunately is too advanced to be deciphered by myself.
Could be this an example of what I am asking for?
Being true, I believe it solve all the previous 4 questions. If is true, but somehow it doesn't solve the others previous questions because of any caveats, hope you can mention why (not deep explanations needed since probably I don't gonna understand, better save your time). As example of a possible issue, the paper also claim holding uniqueness of solutions, which should be broken when a solution becomes zero in a non-zero measure domain, but this issue is already asked in this another question.
Also I would like to extend the question if the last paper is indeed a valid example: Are there examples of solutions with finite extinction time being used in Special/General Relativity frameworks?
Last Update:
I found another paper talking about finite extinction times in differential geometry/topology:
But later I found the author is indeed Grigori Perelman (see the last paper $P03b$), the mathematician that refuse the Field Medal and the Millennium Problems' prize for solving the Poincaré conjecture, so maybe the field is still too new for having this finite extinction times applied in solutions to physics problems... but I don't really know (at least I found the previous paper), so I hope it is not the case.
