The statement appears on page 33 of the second edition of Professor Lee's Introduction to Riemannian Manifolds. It is in the section on Lengths and Distances in Riemannian manifolds, but I think the statement may be generally true even if there is no Riemannian metric given for the manifold. Here is the relevant paragraph:
"Without further qualification, a curve in $M$ always means a parameterized curve, that is, a continuous map $\gamma\colon I\to M$, where $I\subseteq\mathbb{R}$ is some interval. ... To say that $\gamma$ is a smooth curve is to say that it is smooth as a map from the manifold (with boundary) $I$ to $M$. If $I$ has one or two endpoints and $M$ has empty boundary, then $\gamma$ is smooth if and only if it extends to a smooth curve defined on some open interval containing $I$. (If $\partial M\neq\varnothing$, then smoothness of $\gamma$ has to be interpreted as meaning that each coordinate representation of $\gamma$ has a smooth extension to an open interval.)"
I believe I have a correct proof of the statement for the case when $M$ has empty boundary. It is the parenthetical statement that follows, about the case when the boundary of $M$ is nonempty, that has me stymied. I have sketched a proof of one direction of that statement, namely the "if" direction. It is the "only if" direction that I can't get a handle on.
That is, I assume that $\gamma$ is smooth, $(U,\phi)$ is a smooth chart for $I$, $(V,\psi)$ is a smooth chart for $M$, and $\gamma(U)\subseteq V$. I set $\hat{\gamma}=\psi\circ\gamma\circ\phi^{-1}\colon\phi(U)\to\psi(V)$. By definition, $\hat{\gamma}$ (which is a coordinate representation of $\gamma$) is smooth, and I need to find an open interval $J$ which contains $\phi(U)$ and a smooth map $\Gamma\colon J\to\mathbf{R}^n$ such that $\Gamma|_{\phi(U)}=\hat{\gamma}$. Here, I have assumed that $\dim M=n$. I tried to work on a simpler version of this problem, so I assumed first that $\phi(U)$ was open in $\mathbb{R}$ (it could be open in the half-space instead). Then a plausible candidate for $J$ is $(\inf\phi(U),\sup\phi(U))$. But how would I define $\Gamma$ so as to match $\hat{\gamma}$? I know $\phi(U)$ is a countable collection of disjoint open intervals, but I haven't been able to figure out how to use something like a partition of unity to glue the restrictions of $\hat{\gamma}$ to each interval in the collection together to make $\Gamma$. That is mostly because I haven't come up with a reasonable open cover for $J$. Also complicating things is that an interval which appears in $\phi(U)$ might actually have been flipped by $\phi$ compared to the interval it came from in $I$. For example, if $(-1,1)\subseteq I$, $\phi$ might multiply it by $-1$ but not do that to other nearby subintervals.
Can someone please offer some suggestions on how to go about proving the parenthetical statement.
    Sorry, I just noticed this question. The whole issue of whether a coordinate representation can be extended to an interval is a red herring. I realize now that it's much easier to treat this case by embedding $M$ in a smooth manifold $\widetilde M$ without boundary and extending $\gamma$ itself as a map into $\widetilde M$. I've added this to my list of corrections. – Jack Lee Sep 04 '22 at 21:27
The condition
is inadequate. It has to be replaced by
If $\partial M\neq\varnothing$, then smoothness of $\gamma$ has to be interpreted as meaning that each coordinate representation $\hat \gamma : \phi(U) \to \psi(V)$ of $\gamma$ has a smooth extension to an open subset $V \subset \mathbb R$ containing $\phi(U)$.
Let us recall the definition of a smooth map $f :A \to \mathbb R^k$ on an arbitrary subset $A \subset \mathbb R^n$ given in Appendix A (Review of Smooth Manifolds) p. 374 :
First, we note that when $U $is an open subset of $\mathbb R^n$, a map $F : U \to \mathbb R^k$ is said to be smooth (or of class $C^\infty$) if all of its component functions have continuous partial derivatives of all orders. More generally, if the domain $U$ is an arbitrary subset of $\mathbb R^n$, not necessarily open (such as a relatively open subset of $\mathbb R^n_+$), then $F$ is said to be smooth if for each $x \in U$, $F$ has a smooth extension to a neighborhood of $x$ in $\mathbb R^n$.
Also have a look to p. 20 and p. 428 of [John M. Lee, Introduction to Smooth Manifolds, 2nd ed., Graduate Texts in Mathematics, vol. 218, Springer, New York, 2013].
Let us emphasize that the above requirement ($F$ has a smooth extension to a neighborhood of $x$) may be a bit misleading. It means that there exists an open neigborhood $W$ of $x$ in $\mathbb R^n$ and a smooth map $F_x : W \to \mathbb R^k$ such that $F_x \mid_{U \cap W} = F \mid_{U \cap W}$. It is therefore only relevant for points $x$ which do not belong to the topological interior of $U$ in $\mathbb R^n$.
Now consider your coordinate representation $\hat \gamma$. The chart $(\psi,V)$ maps $V$ to an open subset $V' \subset \mathbb R^k_+$. This set is open in $\mathbb R^k$ if $M$ has no boundary or $V$ is contained in the interior of $M$. Anyway, we regard $\hat \gamma$ as a map into $\mathbb R^k$.
$U$ is an open subset of $I$ which is mapped by $\phi$ to an open subset $U' = \phi(U) \subset \mathbb R_+$. This set is either open in $\mathbb R$ or contains $0 \in \mathbb R_+$. The above smooth extension condition is only relevant for $x = 0$ provided $0 \in U'$. In this case the definition of smooth says that there exists an open neighborhood $W$ of $0$ in $\mathbb R$ and a smooth $\gamma^* : W \to \mathbb R^k$ such that $\gamma^* \mid_{U' \cap W} = \hat \gamma \mid_{U' \cap W}$. Then $\hat \gamma$ and $\gamma^* \mid_{W \cap (-\infty,0]}$ can be pasted to a smooth $\bar \gamma : U' \cup (W \cap (-\infty,0]) \to \mathbb R^k$ which is an extension of $\bar \gamma$ to an open set containing $U'$.
Why is it impossible to require that $\hat \gamma$ has a smooth extension to an open interval? The reason is simple: The set $\hat\gamma^{-1}(\partial M)$ is in general not be an interval, but the disjoint union of open intervals and at most one interval of the form $[0,r)$. We certainly find a smooth map $\gamma^* : (-s,r) \to \mathbb R^k$ extending $\hat \gamma \mid_{[0,r)}$, but $(-s,r) \cup U'$ is not an interval.
Paul Frost
  • 76,394
  • 43
  • 125
  • Thanks for your reply. It would be an acceptable answer if we knew that $\phi(U)$ was some kind of interval. But as I mentioned in the post, all I know is that $\phi(U)$ is open in $\mathbb{R}$ or the half-space, which is why I mentioned that in the former case, it was a countable union of open intervals. There can be gaps between the intervals, and what you suggested does not provide neighborhoods of points in the gaps and smooth maps on those neighborhoods. – Jeff Rubin May 22 '22 at 17:46
  • @JeffRubin You are right. See my update. – Paul Frost May 22 '22 at 23:14
  • This looks right to me, so I will accept this answer. I guess it should really be its own question, but I'd love to see a counterexample. That is, a specific example of a smooth map $\gamma\colon I\to M$ on some interval $I$, and some specific charts $(U,\phi)$ for $I$ and $(V,\psi)$ for $M$ such that $\hat{\gamma}=\psi\circ\gamma\circ\phi^{-1}\colon\phi(U)\to\mathbb{R}^n$ has no smooth extension to an open interval containing $\phi(U)$. – Jeff Rubin May 25 '22 at 00:24
  • @JeffRubin I think you should ask a new question. – Paul Frost May 25 '22 at 09:01
  • I have one further comment on this. After reviewing, it appears to me that the change for the parenthetical statement that would be more in line with how this is used later in the text in Theorem 4.24, is that whenever a coordinate representation is on an interval, then it can be extended to a smooth map on a containing open interval. I can prove the statement with this change. – Jeff Rubin May 25 '22 at 16:50
  • @JeffRubin You are right, it is easy to see that in the definition of a smooth map $f$ is sufficient to restrict to charts with connected domains such that $f(U) \subset V$. – Paul Frost May 25 '22 at 17:27
  • @PaulFrost Hi professor, could I ask your assistance here, please? Forgive the bother. – Antonio Maria Di Mauro Jun 01 '22 at 09:27
  • @AntonioMariaDiMauro It seems that your question has been answered by the comments of C Squared . – Paul Frost Jun 03 '22 at 09:48
  • @PaulFrost Okay, I am cheerful for this. However could I ask your assistance here now, please? Forgive the bother. – Antonio Maria Di Mauro Jun 03 '22 at 10:26
  • @PaulFrost I'm sure I'm on the verge of a solution, but unfortunately it seems my mind suddenly clouded so that I thought I'd seek assistance from someone more experienced than myself. – Antonio Maria Di Mauro Jun 03 '22 at 10:29
