Lets suppose we have 16 different objects and we want to place them in four different boxes containing $4$ each . We need to find the probability of specific two objects lets say $a_1,a_2$ to be together in a box .
What i did was favourable cases would be:
$\binom{14}{2} * \binom{12}{4} * \binom{8}{4}*\binom{4}{4}$ * 4 , this is the case of those two to be lets say in first box and then other distribution in rest boxes , and similarily other three cases of those two to be in other three boxes . Sample space would be $\binom{16}{4} * \binom{12}{4} * \binom{8}{4}*\binom{4}{4}$ dividing both gives the required answer , but i would like if there is a quicker/shorter way to get the same answer .
This post has that method but i am not able to fully comprehend how it does : There are 15 balls named from A to O.
  • I don't understand how one could get quicker than this. It is juts a multiplication problem once you have the formula – tryst with freedom May 15 '22 at 17:02
  • I mean alterante approach which doesnt lead counting like i did , as to why i am asking , see this problem where the solution given was way shorter than what my method or the op method from that post gives . https://math.stackexchange.com/q/3909366/1021792 @Aplateofmomos – ProblemDestroyer May 15 '22 at 17:05
  • Say the two specific objects are $A$ and $B$. Once you place object $A$ in a box, think of the placements as $A _ _ _ _ .._$. That is $15$ places for $B$ but only $3$ of them will lead to $B$ being in the same box as $A$. – Math Lover May 15 '22 at 17:10
  • 15 places for B?? something sounds wrong there @MathLover – tryst with freedom May 15 '22 at 17:12
  • $B$ can either be any of the $3$ objects in the same box as $A$ or it can be any of the $12$ objects in other three boxes. – Math Lover May 15 '22 at 17:17
  • @MathLover in my approach i considered the inside the boxes they are indistinguishable only which of them are what is considered ( that is order doesnt matter inside any box ) . Isnt ? – ProblemDestroyer May 15 '22 at 23:22
  • But your method is giving them places inside a box too , which i dont get properly – ProblemDestroyer May 15 '22 at 23:23
Look at my answer here which explains the method for a similar, but more complex problem solved by many methods.
The answer here is thus simply $\dfrac3{15} = \dfrac15$
PS
There they had to be placed in different groups, here they are to be placed in the same group, but the idea behind the solution is the same.
  • Sir i understood , but how we will reasons that probability will come out to be same as the calcualtion usual one ? I mean without calculating values i mean to show there is a bijection in both methods to give sams answer of proabability – ProblemDestroyer May 19 '22 at 14:21
  • Whenever probability is asked for, it is often possible to avoid counting arrangements. Here you can define $E1=$ {event that $a_1$ is in some box}, and $E2=$ {event that $a_2$ is in the same box as $a_1$}. By the general multiplication rule, $P(E1E2) = P(E1)P(E2|E1) = 1*\frac{3}{15}$ – true blue anil May 19 '22 at 15:48
  • Understood thanks Sir :) – ProblemDestroyer May 19 '22 at 20:17
