25
It is known that given $X=(X_1, X_2, \ldots, X_n)$ iid $\sim N(0,1)$, then $X/\sqrt{X_1^2+\cdots+X_n^2}$ is uniformly distributed on the surface of unit sphere.
Intuitively, I know that that's because the probability of $X/\sqrt{X_1^2+\cdots+X_n^2}$ belonging to any region with the same area on the surface should be the same. But how can I prove it mathematically?
cardinal
  • 7,420
Julie
  • 1,107
Suppose $X=(X_1, X_2, \ldots, X_n)$ iid and $X_1 \sim N(0,1)$, then $X \sim N(0, I_n)$, where $N(0, I_n)$ is the multivariate normal distribution with zero-mean and identity covariance matrix. From that it follows, that if $O$ is an orthogonal matrix, that $OX$ is identically distributed with $X$. From that it follows, that $Y = \frac{X}{||X||_2}$ is identically distributed with $\frac{OX}{||OX||_2} = \frac{OX}{||X||_2}$. From that we can conclude, that $Y$ is invariant under rotations and belongs to the unit sphere. There is only one probability distribution, that satisfies both those conditions at the same time: that is the uniform distribution on the unit sphere.
Chain Markov
  • 15,564
  • 36
  • 116
    Could you explain why there is only one distribution that satisfies invariance under rotations and belonging to the unit sphere? I asked a question about it: https://math.stackexchange.com/questions/4403186/a-random-vector-satisfying-invariance-under-rotation-and-belonging-to-the-unit-s – Zifeng Zhang Mar 18 '22 at 00:18
