From the 3rd edition of the book "The Linear Algebra a Beginning Graduate Student Ought to Know" by Jonathan S. Golan, we find the following exercise under chapter 3:
First of all, let's interpret the term "subspace" as meaning a proper subspace (otherwise we can just choose $V$ itself as the single subspace we need and voilà, all the elements are there and we have disproven the proposition of the question).
Now, I have tried to prove this statement by contradiction, but have fallen short of completing the proof.
Summary of the proof attempt so far...
So to begin, let's assume the opposite. Since $p$ is finite, there must exist some minimal $k^{'}$ s.t. our statement holds. Correspondingly, let our minimal (in number) and sufficient subspaces be denoted by:
$$ S_1, S_2, ..., S_{k^{'}}\ s.t.\ \bigcup_{i=1}^{k^{'}}S_i=V$$
Note that by minimality, all subspaces have to be non-degenerate (more than just ${0_V}$). Now, Let:
$$\bigcup_{i=2}^{k^{'}}S_i=S_{tail}$$
Clearly, both $S_1$ must have at least 1 element that is not in $S_{tail}$ and vice versa. Otherwise, all elements from one subspace/set would be contained in the other, and the subspace / set of subspaces with "repeated" elements could be dropped from the initial minimal list, but this would contradict our assumption that $k^{'}$ is the minimal number for the number of subspaces needed to contain all the elements of $V$.
So, at least one element must exist on both sides that is not found in the other side. Take such elements from both sides and add them. The resultant $s_1 + s_{tail}$ can not be in $S_1$, as otherwise the element $s_{tail}$ would be in $S_1$, leading to a contradiction. On the other hand, let $i$ denote an index from $\{2,...,k^{'}\}$ s.t. $s_{tail} \in S_i$. By the same argument, we have: $s_1 + s_{tail} \notin S_i$.
However, unless $k^{'}=2$, we can not take the final step of our proof. Indeed we want to show that $s_1 + s_{tail} \notin S_{tail}$, as we will have then identified an element of $V$ (namely: $s_1 + s_{tail}$) that is not in $\bigcup_{i=1}^{k^{'}}S_i$, leading to a contradiction that completes our proof.
However, since $S_{tail}$ is not a subspace because it is simply a union of subspaces of $V$, our previous argument can not be symmetrically applied to finish this proof and we are left at an impasse (e.g. it could be that for some $j \in \{2,...,i-1,i+1,...,k^{'}\}$, it holds that $s_1 + s_{tail} \in S_j$).
Hence, this proof falls short at the final step. Now I believe that if this proof by contradiction can be finished, we will have to exploit the fact that $F = GF(p)$, as we have not touched upon it at all in this proof.
Perhaps we have to exploit the fact that all subspaces have orders of the form $n(p-1) + 1$ for $n \in \mathbb{N} $, or perhaps that all elements have an additive order of $p$. Perhaps we have to split the cases where $V$ is finitely generated and where it is not... It is worth noting that our argument can be completed if $k^{'}=2$, as we then can in fact apply our argument symmetrically. Maybe we can then proceed by induction up to $p$?
Could you help me out if you have any ideas or clues (or an alternative way of deriving the result). Thank you!
