Fake proof: Let $X$ and $Y$ be separable Banach spaces. We know that the space $\mathcal{L}(X,Y)$ of bounded operators $X \to Y$ endowed with the operator norm is itself a Banach space. (Cf. [1][2][3].) So we need to show that $\mathcal{L}(X,Y)$ is separable.
It is known (cf. p.14 of Alexander S. Kechris, Classical Descriptive Set Theory) that the closed unit ball of $\mathcal{L}(X,Y)$ with the subspace topology inherited from the strong operator topology of $\mathcal{L}(X,Y)$ is separable. (Cf. [4][5].)
However, if the unit ball of a normed vector space is separable, then the entire vector space must be separable. (Cf. [6][7].) Therefore $\mathcal{L}(X,Y)$ is separable (in the strong operator topology), so "$\mathcal{L}(X,Y)$ is a separable Banach space".
Why proof is fake (?): The main issue is that the operator norm topology on $\mathcal{L}(X,Y)$ is being conflated with the strong operator topology on $\mathcal{L}(X,Y)$. Is that correct?
The strong operator topology on $\mathcal{L}(X,Y)$ is separable but need not be (complete) metrizable. In contrast, the operator norm topology on $\mathcal{L}(X,Y)$ is (complete) metrizable but need not be separable. (Cf. [8][9].) Is that correct?
E.g. in general the strong operator topology on $\mathcal{L}(X,Y)$ is generated by semi-norms [10] in some sense related to the operator norm, but in general is not even metrizable [11] and thus clearly not induced by the operator norm and not a Banach space. Cf. also this question [12].
Yes, you are correct. Separability for different topologies bears no relation.
You can see this clearly when $X=Y=\ell^2(\mathbb N)$. You can embed $A=\ell^\infty(\mathbb N)$ into $L(X)$ as multiplication operators. That is $$M_xy=(x_ny_n).$$ This embedding is isometric when you consider the operator norm. As $A$ is not separable, neither is $L(X)$. On the other hand, $L(X)$ is separable in the strong/weak operator topology since $X$ is separable and the finite-rank operators are dense in $L(X)$ in the weak/strong operator topology.
Martin Argerami
  • 205,756
  • To clarify, what is the relationship between compactness and separability of the unit ball being used here? Or is it just that the proof that (unit ball separable) $\implies$ (whole space is separable) requires the assumption that the unit ball is compact? Is this referring to a special case of Banach-Alaoglu? https://en.wikipedia.org/wiki/Banach%E2%80%93Alaoglu_theorem#Sequential_Banach%E2%80%93Alaoglu_theorem Sorry, my functional analysis is really rusty and was never very good to begin with, that's why I was confused about this at first before realizing the argument is wrong. – hasManyStupidQuestions Mar 03 '22 at 21:09
  • Sorry, is it just that compactness is a sufficient condition for separability in this case? (Because closed unit ball is closed subspace of complete metric space induced by the norm, so a complete metric space) https://math.stackexchange.com/questions/974233/prove-if-x-is-a-compact-metric-space-then-x-is-separable – hasManyStupidQuestions Mar 03 '22 at 21:13
    My bad. I have no idea why I talked about compactness. Answer edited. – Martin Argerami Mar 03 '22 at 21:37
  • No worries, the given example is still really clear/good/helpful/etc. – hasManyStupidQuestions Mar 04 '22 at 01:21
