I think I found an error in the nLab page on partial combinatory algebra in the Example combinators section:
Finally, consider the classical construction of the fixed-point combinator, $Y = \lambda y. (\lambda x. y(x x))(\lambda x. y(x x))$. We have firstly $$\lambda x. y(x x) = s(\lambda x. y)(\lambda x. x x) = s(k y)(s I I)$$ which means $$\array{ Y & = & \lambda y. (s I I)(s(k y)(s I I)) & (1)\\ & = & s(\lambda y. s I I)(\lambda y. s(k y)(s I I)) & (2)\\ & = & s(k (s I I))(s(\lambda y. s(k y))(\lambda y. s I I) & (3) \\ & = & s(k (s I I))(s(s (k s)(\lambda y. k y)))(k (s I I)) & (4) \\ & = & s(k (s I I))(s(s (k s)(s(k k)I)))(k (s I I)) & (5) }$$
I think I found an error.
$(3)$ has a missing closing parenthesis, i.e. $\big)$. The closing parenthesis can go in one of two positions. The error stems from there.
$(2)$ is equivalent to $(3)$ with a trailing closing parenthesis (emphasized):
$$s(k (s I I))(s(\lambda y. s(k y))(\lambda y. s I I)\Big)\qquad(3a)$$
On the other hand, $(4)$ is equivalent to $(3)$ with a closing parenthesis in the other possible position (emphasized):
$$s(k (s I I))(s(\lambda y. s(k y))\Big)(\lambda y. s I I)\qquad (3b)$$
Can someone with patience confirm? I’d use the SKI combinator interpreter to double check, but it supports purely SKI input only (can’t mix in $\lambda$, variables, nor terms).
user43208
  • 8,289
joseville
  • 1,477
    Are you sure the (1) step is correct? I see above your quoted section we have $λx.xx=s(λx.x)(λx.x)=sII$, but Y has no $λx.xx$ part... – cinch Dec 13 '21 at 00:14
  • Yes, it’s surprising, but yes. @Taroccoesbrocco’s answer addresses this! – joseville Dec 13 '21 at 02:13
    Nice follow-up work over the weekend! Maybe (dependent) type theory is your next topic? :) – cinch Dec 13 '21 at 04:05
  • @mohottnad Thanks! Yes, I want to read "Types and Programming Languages" (TAPL) by Pierce. The first pages of TAPL outlined some prereqs that I need and suggested "Essentials of Programming Languages" (EOPL) by Friedman/Wand/Haynes as a way to get those prereqs (with "Programming Language Pragmatics" (PLP) by Scott as an alternative way to get the prereqs). I read that PLP is more of a reference book, so I decided on EOPL. EOPL tells me I need to know Scheme, but recommends "The Little Schemer" by Friedman, so I started reading "The Little Schemer" over the weekend. – joseville Dec 13 '21 at 04:30
  • My current plan is "The Little Schemer", then EOPL, then TAPL. Let me know if you have any advice and thanks for all the help (answering so many questions and clarifications!) and encouragement! – joseville Dec 13 '21 at 04:30
    I haven't read any of the above CS oriented type theory books though I have some programming experience. Hope to continue to be able to help you and good learning! – cinch Dec 13 '21 at 05:17
  • @mohottnad thanks! Have learned much from your answers. – joseville Dec 13 '21 at 12:09
I totally agree that what you have noticed is the only error among the equivalences, well spotted!
A missing parenthesis leads to the completely wrong conclusion that $S(K(SII))(S(S(KS)(S(KK)I)))(K(SII))$ is a fixed point combinator! A proof that $S(K(SII))(S(S(KS)(S(KK)I)))(K(SII))$ is not a fixed point combinator is here.
To @mohottnad: Equivalence $(1)$ is$-$quite surprisingly$-$correct! Indeed,
$$Y = \lambda y. (\lambda x. y(xx)) (\lambda x. y(xx))$$ and we have that \begin{align} \lambda x. y(xx) &=_\beta S(Ky)(SII) \\ \lambda x.xx &=_\beta SII \end{align} Since $(\lambda x.xx)(\lambda x.y(xx)) =_\beta (\lambda x.y(xx))(\lambda x.y(xx))$, we can conclude that \begin{align} Y &=_\beta \lambda y.(\lambda x.xx)(\lambda x.y(xx)) \\ &=_\beta \lambda y.(SII)(S(Ky)(SII)) \end{align}
I agree that the explanation on nLab's page could be a bit more lengthy and thorough. At first sight, I was convinced that equivalence $(1)$ was wrong, too.
An emended version of the equivalences in nLab's page about partial combinatory algebra, Point 4 in section Examples of Combinators, would be the following:
\begin{align} Y & =_\beta \lambda y. (S I I)(S(K y)(S I I)) \\ & =_\beta S(\lambda y. S I I)(\lambda y. S(K y)(S I I)) \\ & =_\beta S(K(S I I)) \big(S(\lambda y. S(K y))(\lambda y. S I I)\big) \\ &=_\beta S(K(SII)) \big(S(S(KS)K)(K(SII))\big) \end{align}
where, in the last equivalence, we used the fact that \begin{align} S(S(KS)K)(K(SII)) &\to_\beta^* S (\lambda y.(KSy)(Ky)) (K(SII)) \\ &\to_\beta^* S (\lambda y. S(Ky)) (K(SII)) \\ &\to_\beta S(\lambda y. S(K y))(\lambda y. S I I) \end{align}
Therefore, $S(K(SII)) \big(S(S(KS)K)(K(SII))\big) $ is a fixed point combinator, and this is consistent with Wikipedia's page about fixed point combinators.
    Nice explanation and hard work! +1 – cinch Dec 13 '21 at 00:39
  • Thanks! I’m now trying to fix the derivation by proceeding from $(3a)$ in OP. I’m stuck at converting $(\lambda y.s(ky))$ into an expression exclusively of $SKI$ terms. $\lambda y.s(ky) \rightarrow_{\beta} \lambda xyz.x(yz)$. Not sure how to proceed. Should I make this a separate question of its own? – joseville Dec 13 '21 at 02:17
    @joseville - I edited my answer to show a correct derivation of the equivalences. – Taroccoesbrocco Dec 13 '21 at 03:38
    Thanks! I corrected the two “nLab” pages and linked to this answer in the revision notes. – joseville Dec 13 '21 at 20:51
