Here is my problem and subsequent attempted proof:
Assume we have $n$ different colored balls and $k$ of each color for a total of $nk$ balls. We want to draw from this set without replacement until we have seen at least one of each color.
Let $D_m$ define the number of distinct colored balls seen after $m$ draws from the defined set. Therefore, $D_m$ has the same probability distribution as the number of draws with replacement until each color is drawn. When sampling with replacement, we have that $m \approx n \log n$ (see coupon collector problem) so this will serve as an upperbound on $\mathbb{E}[D_m]$. Furthermore, if $k = 1$ then we have $n$ different balls and $n$ balls total, so we must draw each one to see each type.
The probability of drawing any ball on drawing $m$ is $$1 - \left(1 - \frac{1}{nk}\right)^m$$ Therefore, the expectation of $D_m$ is $$\mathbb{E}[D_m] = nk \left[ 1 - \left(1 - \frac{1}{nk}\right)^m\right] \rightarrow nk \left(1 - e^{-m/nk}\right) \text{ for $n \gg 1$}$$ Now let $m = c \cdot n \log n$ for some $c \in (0,1)$. This simplifies our expectation to $$\mathbb{E}[D_m] = nk \left(1-e^{-c \log n/k}\right) < nk\left(1-e^{-\log n/k}\right)$$ We now consider two cases, dependent upon the relative value of $k$ to $n$:
$\underline{\textit{Case I:}}$ $\lim_{n \rightarrow \infty}\frac{k}{\log n} = 0$ $$\lim_{n \rightarrow \infty}\mathbb{E}[D_m] = nk(1-0) = nk$$
$\underline{\textit{Case II:}}$ $\lim_{n \rightarrow \infty}\frac{k}{\log n} = \infty$
In this case, since $n \log n < nk$ we have by the sample-with-replacement bound that $$\mathbb{E}[D_m] = n \log n < nk$$ Therefore, if $k < \log n$ for all $n \in \mathbb{Z}$, in expectation we will draw every ball to see each type, whereas when $k > \log n$ we need not.
My question is the validity of the approach and namely if two of my "hand-waving" steps are valid: (1) imposing the $n \log n$ upperbound on expectation and (2) definition of $D_m$ as it relates to the sampling with replacement problem?
