Consider the equivalence relation $E$ on $X$ generated by the relation $f(x) = y$ (the reflexive, symmetric, transitive closure of this relation). For each $E$-class $C$, $f$ restricts to an injective function $C\to C$, and $(C,f)$ is isomorphic to $(\mathbb{N},S)$, $(\mathbb{Z},S)$, or $(\mathbb{Z}/n\mathbb{Z},S)$ for some $n$, where $S(x) = x+1$ is the successor function in each case. For each $E$-class, pick an isomorphism with one of these three structures, so we can refer to the elements of $C$ by names from $\mathbb{N}$, $\mathbb{Z}$, or $\mathbb{Z}/n\mathbb{Z}$.
Define a subset $Y\subseteq X$ which contains, for each $E$-class $C$: (1) the odd natural numbers, if $C\cong \mathbb{N}$, (2) the odd integers, if $C\cong \mathbb{Z}$, (3) the odd numbers $k$ with $0\leq k \leq n-1$, if $C\cong \mathbb{Z}/n\mathbb{Z}$.
Case 1: $Y\in U$. Then $f(Y)\in U$, but $Y\cap f(Y) = \varnothing$, contradiction.
Case 2: $Y\notin U$. Let $Z = X\setminus Y$, let $W = Z\cap f(Z)$, and note that $W\in U$. Now $W$ contains no elements of any $E$-class $C$ isomorphic to $\mathbb{N}$, $\mathbb{Z}$, or $\mathbb{Z}/n\mathbb{Z}$ when $n$ is even, since $Z\cap C$ is the even elements of $C$, which are disjoint from their images under $f$. But $W$ contains exactly one element, $0$, from each $E$-class $C$ isomorphic to $\mathbb{Z}/n\mathbb{Z}$ when $n$ is odd (since $n-1$ and $0$ are both in $W$, and $f(n-1) = 0$).
Finally, let $W' = W\cap f(W)$. $W'$ contains exactly one element $0$, from each $E$-class $C$ isomorphic to $\mathbb{Z}/1\mathbb{Z}$, and no elements from any other classes. That is, $W' = \text{Fix}(f)$.
This answer is essentially the same as Gerd's, I've just wrapped in a proof of the theorem of Katetov referred to in Gerd's answer. The three sets $Y_1$, $Y_2$, and $Y_3$ in the theorem can be taken to be: $Y_1 = $ the odd elements from each class, $Y_2 = $ the even elements from each class (except not $0$ from $\mathbb{Z}/n\mathbb{Z}$ when $n$ is odd), and $Y_3 = $ the elements $0$ from each class isomorphic to $\mathbb{Z}/n\mathbb{Z}$ with $n$ odd.
