I am writing a paper in precalculus about series, and one of the sentences I read from arithmetic series is this:
When dealing with arithmetic series, we take only the partial sum. This means that we will be considering only finite series since the terms in an arithmetic series is being obtained by adding the common difference. Thus, the next terms for an infinite arithmetic series will become infinitely large or infinitely small, and its sum cannot be determined.
I get that the sum will become infinitely large if $d > 0$. An example would be $a_1 = 1, d = 1$. What I don't get is that the sum will become infinitely small. It seems like the author is referring to a sum that decreases without bound like $a_1 = 1, d = -1$.
I also think that the term is used in limits. For instance, if $|x - 1| < \varepsilon$ and $\varepsilon$ approaches zero, then $|x - 1|$ be infinitely small and will also approach zero.
However, we also tend to say that something is small by subtracting. Let's say 10 is a large number. To make it smaller, we can subtract 5 to make it smaller, which is now 5.
Is infinitely small referring to a value that is much less than zero?
Edit: I am asking about the usage of 'infinitely small' whether it should refer to the value closer to zero, or values decreasing without bound.
