I would like to use PCA (Principal Component Analysis) to compress a sequence of vectors, $v_0 \ldots v_n$.
My plan is to concatenate these vectors into a matrix: $M = [ v_0 \ldots v_n ]$
I will then use PCA to create a smaller representative set of vectors: $x_0 \ldots x_m$
For each $v_i$, I will then find the weights, $w_0 .. w_m$ such that $w_0 x_0 + \cdots + w_m x_m$ approximates $v_i$.
Assuming this sounds reasonable at the high level, I need to better understand the practical details.
  1. Can anyone point me to a good explanation of the concrete steps for applying PCA, SVD, etc. to solve this problem or similar applied problems? Most of the material I've found is very abstract and self-referential. To use an analogy, it's like looking up ways to use $e$ and reading that $e^{i\pi}=-1$. Although accurate and interesting, it doesn't actually explain $e$, $i$ or $\pi$ or how one would apply any of them to solve common problems.
  2. Can anyone recommend an easy-to-understand free C/C++ library I can use to experiment with numerical PCA in my own code? The simpler and more focused on my problem, the better.
Your approach is correct. There are couple of points you need to decide.
Is $n$ really large? If not, you can use the SVD algorithm (matlab or dgesvd) to get $M = U \Sigma V^T$.
In MATLAB,
[U,S,V] = svd(M);
The columns of $U$ gives your $x_0,x_1,\ldots x_m$ and the weights $w_{jk}$ form the matrix $\Sigma V^T$
In LAPACK, there are some more parameters which you need to pass to your function DGESVD. (Look up the link I have given)
If $n$ is really really large, then there are some really nice approximate/ randomized algorithms which give you the low rank form. One such algorithm is here.
What the SVD does:
If $M \in \mathbb{R}^{m \times n}$ is a matrix of rank $r$, then $M = U \Sigma V^T$ is the singular value decomposition of the matrix $M$ where $U \in \mathbb{R}^{m \times r}$, $V \in \mathbb{R}^{n \times r}$ and $\Sigma \in \mathbb{R}^{r \times r}$.
The matrices $U$ and $V$ are orthonormal matrices i.e. $U^T U = I_{r \times r}$ and $V^T V = I_{r \times r}$ and the matrix $\Sigma$ is a diagonal matrix with positive entries.
This enables us to write the matrix $M$ as $$M = \sigma_1 u_1 v_1^T + \sigma_2 u_2 v_2^T + \cdots + \sigma_r u_r v_r^T$$
There are numerous advantages to SVD. The most important of this being that SVD gives the optimal low rank approximation where the sense of optimality is in the $2-$norm and Frobenius norm sense. (You may want to look up here why the rank of a matrix is important)
What this means is if we are looking for a rank $p$ approximation to the matrix $M$, such that $||M- \tilde{M}||_2$ or $||M- \tilde{M}||_F$ is minimized then $\tilde{M}$ is given by $$\tilde{M} = \sigma_1 u_1 v_1^T + \sigma_2 u_2 v_2^T + \cdots + \sigma_p u_p v_p^T$$
Hence, if we have the SVD of a matrix, then from an application point of view, we have almost all we need to know about the matrix.
