A sphere with a radius of 8 sits in the corner, touching the floor and two walls. A smaller sphere sits between the sphere, touching the floor, the walls, and the larger sphere. What is the radius of the smaller sphere?
I tried to create the smallest cube possible that would fit a sphere with radius 8, and use the long diagonal to determine the diameter of the smaller sphere, but i'm not sure that's correct.
Any and all help is appreciated!
