It is overkill to refer to the Jordan form to answer this question. That a diagonalisable operator$~T$ has a minimal polynomials that (is split and) has simple roots is easy to prove: as any polynomial$~P$ acts on any eigenspace of$~T$ for$~\lambda$ by the scalar$~P[\lambda]$, the annihilating polynomials of$~T$ are precisely those that have every eigenvalue$~\lambda$ as root, so that the minimal polynomial is the product of factors $X-\lambda$ for such$~\lambda$, each factor taken just once.
The converse is a bit harder. One can prove somewhat more generally that if a split polynomial with simple roots $P=\prod_{i=1}^k(X-a_i)$ annihilates$~T$, then the space is a direct sum of the subspaces $V_i=\ker(T-a_iI)$ for $i=1,\ldots,k$, so that $T$ is diagonalisable with its set of eigenvalues contained in $\{a_1,\ldots,a_k\}$. (This will apply in particular when $P$ is the minimal polynomial of$~T$, in case it is split with simple roots.) I know two ways to proceed, one using basic linear algebra technique and one using a bit of polynomial arithmetic.
The first method uses the fact that eigenspaces for distinct eigenvalues form a direct sum, and that the dimension of the kernel of a composition of linear maps is at most the sum of the dimensions of their individual kernels. Note that the kernel of $P[T]=(T-a_1I)\circ\cdots\circ(T-a_kI)$ is the whole space (since the composition is assumed to be zero), so that $\dim(V)\leq\dim(V_1)+\cdots+\dim(V_k)$ by the second mentioned property, while $\dim(V_1)+\cdots+\dim(V_k)=\dim(V_1\oplus\cdots\oplus V_k)$ by the first mentioned property. This shows that the sum of the eigenspaces$~V_i$ fills all of $V$ (and the inequality is an equality), so $T$ is diagonalisable.
For the second method, one may first show that whenever a polynomial $P$ annihilating $T$ decomposes as a product of two relatively prime factors $P=QR$, the space decomposes $V=V_1\oplus V_2$ as a direct sum of $V_1=\ker(Q[T])$ and $V_2=\ker(R[T])$, and the corresponding projections of $V$ on $V_1$ and $V_2$ are given by polynomials in$~T$. To this end write a Bézout relation $AQ+BR=1$, which exists because $Q,R$ are relatively prime, put $\pi_1=(BR)[T]$ and $\pi_2=(AQ)[T]$, so that $\pi_1+\pi_2=I$. Then $\pi_1$ vanishes on $V_2$, and has its image contained in $V_1$ (since $QBR$ is a multiple of $QR=P$, and therefore an annihilating polynomial of $T$) and vice versa for $\pi_2$. Now $v=\pi_1(v)+\pi_2(v)$ for every $v\in V$ shows that $V=V_1+V_2$, while if $v_1\in V_1$ and $v_2\in V_2$ one gets $\pi_1(v_1+v_2)=(\pi_1+\pi_2)(v_1)=v_1$ and similarly $\pi_2(v_1+v_2)=v_2$, so that $V=V_1\oplus V_2$ and $\pi_i$ is the corresponding projection of $V$ onto $V_i$ for $i=1,2$. Applying this result with $Q=X-a_1$ the first factor of $P$ and $R=\prod_{i=2}^k(X-a_i)$ the product of the remaining factors, one gets a direct sum decomposition of$~V$ into the eigenspace $\ker(T-a_1I)$ of $T$ for $a_1$ and a subspace $\ker(R[T])$ restricted to which $R$ is an annihilating polynomial, and which by induction on $k$ can be further decomposed as a direct sum of eigenspaces.
