I am working to solve a given linear system of the form
$$\mathbf{A} \: \mathbf{x} = \mathbf{b}$$
where $\mathbf{x} = \begin{pmatrix} x_1 & x_2 & \cdots & x_n \end{pmatrix}^T$ with additional constraints such as
$$x_i x_j = x_k x_l \quad \text{for some } i,j,k,l \in \{1, \ldots, n \}$$ The quadratic constraints can be written in matrix form as $$\mathbf{x}^T \: \mathbf{P}_m \: \mathbf{x} = 0, \quad m \in {1, \ldots, M}$$ for say $m$ constraints. In compact form, the problem I am trying to solve is \begin{align} \widehat{\mathbf{x}} &= \arg \min \vert \vert \mathbf{A} \: \mathbf{x} - \mathbf{b} \vert \vert^2\\ &\quad \text{s.t.} \quad \mathbf{x}^T \: \mathbf{P}_m \: \mathbf{x} = 0 \end{align}
The matrix $\mathbf{P}_m$ takes the form $$\begin{pmatrix} 0 & 0 & 0 & 0 & \ldots & 0\\ \vdots & \vdots & \vdots & \vdots & \ldots & \vdots\\ 0 & \ldots & 1 & \ldots & \ldots & 0\\ 0 & 0 & 0 & 0 & \ldots & 0\\ \vdots & \vdots & \vdots & \vdots & \ldots & \vdots\\ 0 & -1 & \ldots & \ldots & \ldots & 0\\ 0 & 0 & 0 & 0 & \ldots & 0\\ \vdots & \vdots & \vdots & \vdots & \ldots & \vdots \end{pmatrix}$$ with one entry as $1$ and another as $-1$ depending upon which constraint it represents. An important point to notice, as pointed out here, is that the matrix $\mathbf{P}_m$ can be replaced by $\mathbf{P}_{m, sym} = \dfrac{\mathbf{P}_m + \mathbf{P}_m^T}{2}$ to yield the same quadratic constraint as the skew-symmetric part has no contribution. In my case, $\mathbf{P}_{m,sym}$ has both positive and negative eigenvalues.
Here are my attempts till now:
Attempt 1: Ignoring any noise in $\mathbf{b}$. I get the accurate answer with the constraints automatically satisfied without explicitly writing them, i.e. the solution is
$$\widehat{\mathbf{x}} = (\mathbf{A} \: \mathbf{A})^{\dagger} \: \mathbf{A}^T \: \mathbf{b}$$
However, as I add noise, this no longer works as the constraints are not included and the solution has more degree of freedom than is required.
Attempt 2: I tried formulating the problem as a QCQP problem which takes the following form
\begin{align} \widehat{\mathbf{x}} &= \arg \min \quad \| \mathbf{A} \: \mathbf{x} - \mathbf{b} \|^2 \\ & \quad \quad \mathbf{x}^T \: \mathbf{P}_{m,sym} \: \mathbf{x} \leq \mathbf{0} \quad \text{for } m \in \{1, \ldots, M \}\\ \end{align} for $M$ constraints. Here, I have replace the equality quadratic constraint with inequality to match the general from of the problem as given in the wiki article. As far as I understand, $\mathbf{P}_{m, sym}$ is non-convex as it has both positive and negative eigenvalues. I am trying to use this github package, built on cvxpy,to solve this non-convex problem but the solutions I get are not correct.
Attempt 3: Using method of Lagrange multipliers from Sympy package. However, it does not lead to any solution as the computation goes on forever. Here is a sample code as a minimum working example.
import sympy as sym
import numpy as np
A = np.array([[-0.968944, -0.436796, 0.196568, 0.271458, -0.430080, 0.124070], [2.150209, -0.029774, 0.019347, -0.059676, 0.008842, 0.130567], [-2.834933, 4.052180, -0.088795, -0.061756, 0.194278, -0.028226], [4.052180, 2.834933, 0.194278, -0.028226, 0.088795, 0.061756], [8.586872, -1.745449, -0.058274, 0.016471, 0.127501, 0.007528], [-1.745449, -8.586872, 0.127501, 0.007528, 0.058274, -0.016471], [-0.992538, 0.352622, 0.157250, -0.280853, -0.344055, -0.128364], [0.352622, 0.992538, -0.344055, -0.128364, -0.157250, 0.280853], [2.299443, -2.015109, 0.111921, -0.412508, -0.244876, -0.188537], [-2.015109, -2.299443, -0.244876, -0.188537, -0.111921, 0.412508], [-3.308854, 2.438692, -0.165180, 0.006687, 0.361404, 0.003056], [2.438692, 3.308854, 0.361404, 0.003056, 0.165180, -0.006687], [-0.503533, 5.245499, 0.075566, 0.620638, -0.165335, 0.283663], [5.245499, 0.503533, -0.165335, 0.283663, -0.075566, -0.620638], [4.892830, -14.009709, -0.058637, 0.312733, 0.128294, 0.142935], [-14.009709, -4.892830, 0.128294, 0.142935, 0.058637, -0.312733], [-3.866142, -3.279746, 0.221616, 0.017314, -0.484883, 0.007913], [-3.279746, 3.866142, -0.484883, 0.007913, -0.221616, -0.017314]])
b = np.array([[-0.026581], [1.695003], [0.657257], [5.048084], [4.922790], [-7.270629],[-1.589395], [1.193584], [-1.423906], [-2.574324], [-0.527349], [4.221735], [5.705906], [3.101335], [-5.224569], [-13.753907], [-5.070051], [0.165608]])
x0, x1, x2, x3, x4, x5, mu1, mu2 = sym.symbols('x0 x1 x2 x3 x4 x5 mu1 mu2', real=True)
x = sym.Matrix([[x0], [x1], [x2], [x3], [x4], [x5]])
A_sym = sym.Matrix(np.array(A))
b_sym = sym.Matrix(np.array(b))
expr = A_sym * x - b_sym
cost = sym.Transpose(expr) * expr
L = cost[0] + mu1 * (x1 * x2 - x0 * x4) + mu2 * (x1 * x3 - x0 * x5)
sol = sym.solve_poly_system([sym.diff(L, x0), sym.diff(L, x1), sym.diff(L, x2), sym.diff(L, x3), sym.diff(L, x4), sym.diff(L, x5), sym.diff(L, mu1), sym.diff(L, mu2)], x0, x1, x2, x3, x4, x5, mu1, mu2)
The solution I am expecting here is: $$x = \begin{bmatrix} 0.707107 & 0.707107 & 0.317454 & 2.633335 & 0.317454 & 2.633335 \end{bmatrix}^T$$
Question: Is the problem solvable and if yes which package can be used in Python to solve it. Any references will be appreciated!
