I do not know how to solve this integer programming problem. $$\min_{w_{i,j}} \sum_{i=1}^{N}\sum_{j=1,j \neq i}^{N} w_{i,j}$$ $$s.t. \sum_{j=1,j \neq i}^{N} w_{i,j} \geq L, \forall i \in \left[ N \right]$$ $$w_{i,j} = w_{j,i}, \forall i \in \left[ N \right], j \in \left[ N \right], i \neq j$$ $$w_{i,j} \in \left[ S \right], \forall i \in \left[ N \right], j \in \left[ N \right], i \neq j$$
$L$ is a positive integer, $\left[ N \right]$ is a set of positive integers and $\left[ N \right] = \left\{ 1, 2, \dots, N \right\}$, $\left[ S \right]$ is a set of non-negative integers and $\left[ S \right] = \left\{0, 1, \dots, N \right\}$
You can use an integer programming package (e.g. mips in python) to solve the problem, first you need to define the variables in order to express the objective function and the constraints and define the parameter ($N, L$) values:
from sys import stdout
from mip import Model, xsum, INTEGER
N = 10 L = 2
model = Model()
w = [[model.add_var('w({},{})'.format(i, j), var_type=INTEGER, lb=0, ub=N) for j in range(N)] for i in range(N)]
model.objective = xsum(w[i][j]*(i!=j) for i in range(N) for j in range(N))
for i in range(N): model.add_constr(xsum(w[i][j]*(i!=j) for j in range(N)) >= L)
for i in range(N): for j in range(N): model.add_constr(w[i][j] == w[j][i])
model.optimize()
if model.num_solutions: stdout.write('\n') for i, v in enumerate(model.vars): stdout.write(str(int(v.x))) if i % N == N-1: stdout.write('\n')
solution
0000000020
0000002000
0000100100
0000010001
0010000100
0001000001
0200000000
0010100000
2000000000
0001010000
The above solution to be interpreted as $w_{1,9}=2$, $w_{2,7}=2$, $w_{3,5}=w_{3,8}=1$ etc.
Sandipan Dey
  • 2,111
