I'm stuck on an issue involving volumetric scale.
I tried to multiply the dimensions 2 cm × 3.51 cm × 4 cm, I got the result 28.08, and I believe the result must contain cm³, because I multiplied the factors 3 times... The problem is that I can't find the scale.
I tried to do the following:
2808 / 28080
I divided 2808 by itself, getting the result 1.
Then, dividing 28080 by 2808, I got 1000 as a result, so the scale I found was 1:1000, but this is not the correct answer.
I think my reasoning makes sense, however, I can't get to the answer.
I hope someone can help me and guide me about my mistakes
Question:
The water tank of a building will have the shape of a
straight rectangle parallelepiped with volume equal to
28 080 liters. In a model that represents the building,
the water tank has dimensions 2 cm × 3.51 cm × 4 cm.
Given: 1 dm³ = 1 L.
The scale used by the architect was
a) 1 : 10
b) 1 : 100
c) 1 : 1 000
d) 1 : 10 000
e) 1 : 100 000
