If we know the following convergence criteria for infinite products is correct
$$\boxed{\sum a_{n}\text{ converges }\Leftrightarrow\prod\left(1+a_{n}\right)\text{ converges, for real }a_{n}>0}$$
Then it immediately follows that
$$\boxed{\sum|a_{n}|\text{ converges }\Leftrightarrow\prod(1+|a_{n}|)\text{ converges}}$$
because $|a_n|>0$, even for complex $a_n$ as required by the first criteria.
Question: This this logic correct? I am asking because I have seen source which derive the first criterion (eg), and then derive the second in a complicated way. What am I missing?
If your sequence does contain $0$-terms then removing them does not change the convergence of either series or product, so then you reduce to the prior case and then what you whish to prove holds.
– user2628206 Aug 08 '21 at 17:56
