Actually I am working with a overdetermined homogeneous system of linear equations $Ax=0$. In literature I found, that a least square result can be found with helpf of SVD. The solution is the eigenvector corresponding to the smallest eigenvalue of $A^TA$.
So far so good. But in some literature I could read, that one should look for the eigenvalue/eigenvector of $A$. Unfortunately I cannot find the literature, which says $A$ instead of $A^TA$.
Does the method change, if the system is not overdetermined?
Please help me to solve my confusion. Thanks.
IFeelGood
  • 113
Blueshark
  • 50
  • The least-squares solution to $Ax = 0$ is always $x=0$. I guess you mean $Ax = b$. Then, and if $A$ has full rank, the least squares solution is that of $A^TAx = A^Tb$, i.e., $x = (A^TA)^{-1}A^Tb$. – amsmath Aug 01 '21 at 00:33
  • I had in mind the non trivial solution for $Ax=0$. The solutions form a hyperspace, so another constraint is needed. In Literatur $||x||=1$ is mentioned, which I had in mind.
    I forgot to mention this.
    – Blueshark Aug 01 '21 at 14:59
  • Then your system is not overdetermined, but underdetermined. The matrix $A$ is wide and fat and not slim and tall. – amsmath Aug 01 '21 at 15:04
  • “I had in mind 'the' nontrivial solution for $Ax=0$.” If there is a nontrivial solution to $Ax =0$, then there are infinitely many nontrivial solutions. In that case, you can find a nontrivial solution whose norm is as small as you like. – littleO Jul 24 '22 at 06:07
With the answer and the comments I finally could answer the question by myself and solve my confusion. Thanks again for putting me on the right track. Both leads to a valid solution.
Edit: And as user amsmath commented, it always holds that $min_{||x||=1}||Ax|| = min_{||x||=1}\sqrt{\langle A^TAx, x \rangle}$ which is always (!) the square root of the smallest eigenvalue of $A^TA$ (and at the same time the smallest singular value of $A$)
An overdetermined homogeneous linear equation system can be represented as $Ax=0$, where $A\in R^{m\times n}$ with $m>n$ subject to $||x||=1$. Desired is a non trivial solution ($x\neq 0$), which minimizes $||Ax||$. Solutions form a hyperspace. If $x_0$ is a solution, then $\kappa x_0$ for $\kappa \in R$ is also a solution.
Case 1 - Solution is the right-singular vector corresponding to the smallest singular value of $A$
Edit: I was mixing up eigenvalues and singular value. Beeing precise helps to improve understanding. In that post the difference of eigenvalues and singular values is discussed.
We are looking for an $x$ that minimizes $||Ax||$ subject to $||x||$. The SVD decomposition of $A$ leads to $$A = UDV^T,$$ where $U\in R^{m\times m}$, $D\in R^{m\times n}$, and $V \in R^{n\times n}$.
Since $U$ is an orthogonal matrix $$||Ax||=||UDV^Tx||$$ leads to $$||Ax||=||DV^Tx||.$$
$V$ is also an orthogonal matrix. So if $||x||=1$ holds, then $||V^Tx||=1$ holds, too. We substitute $V^Tx$ with $y$ and minimizing $||Dy||c$ subject to $||y||=1$. The matrix $D$ is a diagonal matrix $$D=\begin{pmatrix} d_1 & 0 & \dots & 0\\ 0 & d_2 & \dots & 0\\ \vdots & & \ddots & \vdots\\ 0 & 0 & \dots & d_n\\ 0 & 0 & \dots & 0\\ \vdots & \vdots & & \vdots\\ 0 & 0 & \dots & 0\\ \end{pmatrix}\in R^{m\times n},$$ with $d_1 > d_2 > \dots > d_n$ we can minimize $||Dx||$ by chosing $$y = \begin{pmatrix}0\\0\\ \vdots \\ 1\end{pmatrix} \in R^{n\times 1},$$ which satisfy $||y||=1$. The substitution of $V^T$ with $y$ leads to $$x=Vy=\begin{pmatrix}V_{1n}\\V_{2n}\\\vdots\\V_{nn}\end{pmatrix}$$ $\square$
Case 2 - Solution is the eigenvector corresponding to the smallest eigenvalue of $A^TA$.
Applying Lagrange function \begin{align}L(x,\lambda) & := ||Ax|| + \lambda (1-||x||) \\& = x^TA^TAx + \lambda (1-x^Tx) \end{align} Critical points of the Lagrange function are found by equaling derivatives to zeros \begin{align} \frac{\partial L(x,\lambda)}{\partial x} & = 2A^TAx - 2\lambda x = 0\\ \frac{\partial L(x,\lambda)}{\partial \lambda} & = 1- x^Tx = 0 \end{align} First partial derivative can be rewritten as the characteristic polynom $$(A^TA - \lambda I)x = 0$$ of $A^TA$. So every eigenvector $x$ with corresponding eigenvalue $\lambda$ is a critical point and hence a solution for the equation above. We choose the smallest eigenvalue to minimize $||Ax||$. Combining equations lead to \begin{align}||Ax|| &= x^TA^TAx \\ &= x^T\lambda x\\ &= \lambda x^Tx\\ &=\lambda||x||\\& = \lambda \end{align} Therefore the solution is the eigenvector of $A^TA$ with the smallest corresponding eigenvalue. $\square$
Blueshark
  • 50
    "Solution is the eigenvector corresponding to the smallest eigenvalue of $A$" Well, if $A$ is not square, it does not have eigenvalues. The concept of eigenvalues is only defined for square matrices. – amsmath Aug 01 '21 at 22:28
  • $\min_{|x|=1}|Ax| = \min_{|x|=1}\sqrt{\langle A^TAx,x\rangle}$, which is always (!) the square root of the smallest eigenvalue of $A^TA$ (and at the same time the smallest singular value of $A$). – amsmath Aug 01 '21 at 22:33
  • Your are right. I was not precise in the text and revised it. Furthermore the relation you mentioned in second comment was not clear to me. I also added it into the text. – Blueshark Aug 01 '21 at 23:19
If the system is not over-determined then there should be a solution, so you should try to solve the original problem,
$$A x = 0.$$
More generally, it sounds like you want to do something like minimizing the norm of the vector, $A x$. But of course you'd just choose $x=0$. So do you want to instead minimize the norm of $A x$ for a fixed magnitude of $x$?. If so, the way I'd do it is to minimize $(A x)^2 = x^T A^T A x$ subject to the condition $x^T x = 1$. I'd do that by adding the Lagrange multiplier term and enforcing the first-order conditions on:
$$x^T A^T A x + \lambda (x^T x - 1).$$
That is, I'd differentiate it with respect to the vector $x$ and set it equal to zero, yielding:
$$A^T A x + \lambda x = 0.$$
Consequently, indeed, if this is what you want then your answer should be an eigenvector of $A^T A$, specifically any one with the lowest eigenvalue. I think similar analysis applies to the complex case where the transpose is replaced with the conjugate transpose.
David
  • 1,609
  • Thanks for your quick reply. In deed I forgot to mention some details in my question. And with your answer I was able to understand more details.
    I am looking for a non trivial solution of $Ax=0$. In Literatur the condition $||x||=1$ is used. So the task is then to minimize $||Ax||$ with subject $||x||=1$. One best solution fitting the constraint is the eigenvector of $A$ corresponding to the smallest eigenvalue.
    Next question, which comes up to me: If I want to minimize $(Ax)^2$ with subject $||x||=1$, do I then have to look for the eigenvector of $A^TA$ corresp. to smallest eigenvalue?
    – Blueshark Aug 01 '21 at 15:12
  • Thanks @Blueshark glad it was helpful. Per my answer, yes, you want to find the eigenvector corresponding to the lowest eigenvalue of $A^T A$. – David Aug 02 '21 at 02:35
-1
Both the SVD method and the Lagrange method for the non-trivial ‘solution’ of overdetermined homogeneous simultaneous linear equations are described by Patterson (2012). I put the word ‘solution’ in single quote marks as these are almost always not exact solutions, rather a least squares fit. Also note, Patterson (2012) is an application to an ecological network problem, and may fall short of a more complete mathematicial treatment of the topic … that said, I can’t find a a treatment of these 2 solution methods in the more mathematical journals/literature and I would be grateful if anyone could provide me with a reference to any such publication. Reference: Patterson,M.G. 2012. Are all processes equally efficient from an emergy perspective? Analysis of ecological and economic networks using matrix algebra methods. Ecological Modelling Volume 226 pp. 77-91
    Welcome to Math Stack. It seems you are posing new questions here. Do you feel you are also providing an answer to the original question? – 311411 Jul 24 '22 at 05:19
  • Blueshark (above) provided an excellent answer to the original question by outlining 2 solutions to the problem: Case 1 (SVD) and Case 2 (Lagrange method). I was simply asking where such an answer might appear in the journal or academic literature. (I cite one very applied journal article where I used both of these methods. But I am hoping that there may be a more mathematical treatment that someone may be able to identify). So I feel I am not “posing a new question”, rather seeking extra information about Blueshark’s answer to the original question. – Murray Patterson Jul 25 '22 at 00:46
