I am interested in finding a formula for the evaluation of \begin{equation} \int_0^\infty \frac{\cos(x) - 1}{x^{1+\alpha}}dx, \quad 0<\alpha<1. \end{equation} I believe the integral exists as an improper integral, however the calculation becomes tricky due to our choice of $\alpha$. Given the similar look to integrating $\sin x /x$, I decided to try using the Laplace transform. So I let \begin{equation} A(t) = \int_0^\infty \frac{\cos(tx) - 1}{x^{1+\alpha}}dx \end{equation} and then do \begin{align} \mathcal{L}(A)(t) ={}& \int_0^\infty \int_0^\infty \frac{\cos(tx) - 1}{x^{1+\alpha}} e^{-st}dx dt\\ ={}& \int_0^\infty \frac{1}{x^{1+\alpha}} \int_0^\infty (\cos(tx) - 1)e^{-st}dtdx\\ ={}& \int_0^\infty \frac{1}{x^{1+\alpha}} \mathcal{L}(\cos(tx) - 1)(t)dx\\ ={}& \int_0^\infty \frac{1}{x^{1+\alpha}} \left( \frac{s}{s^2+x^2} - \frac{1}{s} \right)dx\\ ={}& - \frac{1}{s} \int_0^\infty \frac{x^{1-\alpha}}{s^2+x^2}dx. \end{align}
Unfortunately I've found myself unable to solve this improper integral. Given that our only condition on $\alpha$ is $0 < \alpha < 1$, it doesn't seem to lend itself to trigonometric substitution. Integration by parts didn't appear to clean anything up either.
I greatly appreciate any clarity or ideas. To be honest, even if I can solve the last improper integral, I can't be sure the inverse Laplace transform will be clean either; so perhaps my initial approach is where I need work. Thank you.
Ritam_Dasgupta
  • 5,992
  • 23
Oreomair
  • 403
    According to Mathematica the integral is equal to $\cos( \pi \alpha /2) \Gamma(-\alpha)$ for $0<\alpha<2$, which is in agreement with some numerical tests I did. I hope this helps! – Hans Olo Jul 29 '21 at 16:26
  • @oreomair In fact, the integral exists for $0<\alpha<2$. Please see my posted solution and let me know how I can improve my answer. I really want to give you the best answer I can. – Mark Viola Jul 29 '21 at 18:18
  • @HansOlo While the result you reported was almost correct (you have the wrong sign), that form seems awkward because (1) the appearance of the Gamma function with negative argument, and (2) the not-so-obvious removeable singularity at $\alpha =1$ since $\cos(\pi \alpha/2)\Gamma(-\alpha)$ is indeterminate as $\alpha \to 1$. Have a look at the solution I posted herein. – Mark Viola Jul 29 '21 at 18:34
  • @MarkViola Yeah, there might a typo, sorry – Hans Olo Jul 29 '21 at 18:37
  • @HansOlo Well, my message was not specifically sent to alert you the the minus sign error. Rather, I wanted to emphasize the two points I enumerated. ;-) – Mark Viola Jul 29 '21 at 19:18
  • Related: https://math.stackexchange.com/q/382412/ (with $\sin x$ instead of $\cos x - 1$, but the methods are very similar). – echinodermata Jul 29 '21 at 21:19
I thought it might be instructive to present an approach that circumvents use of complex analysis and relies on real analysis only. To that end, we now proceed.
Let $I(\alpha)$, $0<\alpha<2$, be given by the integral
$$I(\alpha)=\int_0^\infty \frac{1-\cos(x)}{x^{1+\alpha}}\,dx$$
Let $f(t)=1-\cos(t)$ and $G(s) = \frac1{s^{1+\alpha}}$. Then appealing to this property of the Laplace Transform, we have
$$\begin{align} I(\alpha)&=\int_0^\infty \color{blue}{\mathscr{L}\{f\}(x)} \color{red}{ \mathscr{L^{-1}}\{G\}(x)}\,dx\\\\ &=\int_0^\infty \color{blue}{\frac{1}{x(x^2+1)}}\,\,\,\color{red}{\frac{x^{\alpha}}{\Gamma(1+\alpha)}}\,dx\\\\ &=\frac{1}{\Gamma(1+\alpha)}\int_0^\infty \frac{x^{\alpha-1}}{x^2+1}\,dx\tag1 \end{align}$$
In THIS ANSWER, I showed using real analysis only that the integral on the right-hand side of $(1)$ is given by
$$\int_0^\infty \frac{x^{\alpha-1}}{x^2+1}\,dx=\frac{\pi}{2}\sec\left(\frac{\pi}{2}(\alpha-1)\right)\tag2$$
Using $(2)$ in $(1)$ yields for $\alpha\in (0,2)$
$$\bbox[5px,border:2px solid #C0A000]{I(\alpha)=\frac{\pi}{2\Gamma(1+\alpha)\sin(\pi \alpha/2)}}\tag3\\$$
NOTE: ALTERNATIVE FORM
Using the reflection formula $\Gamma(z)\Gamma(1-z)=\frac{\pi}{\sin(\pi z)}$ for the Gamma function, we can write $(3)$ alternatively as for $\alpha\in (0,2)\setminus { 1}$
$$\bbox[5px,border:2px solid #C0A000]{I(\alpha)=-\cos(\pi \alpha)\Gamma(-\alpha)}\tag4$$
which agrees with previously reported results.
For $\alpha\to 1$, the right-hand side of $(4)$ approaches $\pi/2$. So, if we define $(4)$ as a function with a removeable discontinuity at $\alpha=1$, the the result holds for $\alpha \in (0,2)$.
Mark Viola
  • 179,405
  • thank you so much for the answer. Yes, I was aware that it should work for $0 < \alpha < 2$, but was focusing on $0 < \alpha < 1$ for the time being. Man, I knew the Laplace transform was going in a good direction! – Oreomair Jul 29 '21 at 20:19
Integrating by parts gives that $$ \int_0^{+\infty}\frac{1-\cos(x)}{x^{1+\alpha}}dx=\frac{1}{\alpha}\int_0^{+\infty}\frac{\sin(x)}{x^{\alpha}}dx $$ Let $f(z):=\frac{e^{iz}}{z^{\alpha}}$ and let $\gamma_R$ be the contour integration $[0,R]\cup\left\{Re^{i\vartheta},\vartheta\in\left[0,\frac{\pi}{2}\right]\right\}\cup[iR,0]$. Then because $f$ has no singularities inside the contour, we have $$ \int_{\gamma_R}f(z)dz=0 $$ However, $$ \int_{\gamma_R}f(z)dz=\int_0^R f(t)dt+iR\int_0^{\frac{\pi}{2}}f(Re^{i\vartheta})e^{i\vartheta}d\vartheta-i\int_0^R f(it)dt $$ And, $$ \left|\int_0^{\frac{\pi}{2}}f(Re^{i\vartheta})e^{i\vartheta}d\vartheta\right|\leqslant\frac{1}{R^{\alpha}}\int_0^{\frac{\pi}{2}}e^{-R\sin\vartheta}d\vartheta\leqslant\frac{1}{R^{\alpha}}\int_0^{\frac{\pi}{2}}e^{-R\frac{2}{\pi}\vartheta}d\vartheta\ll\frac{1}{R^{1+\alpha}} $$ Therefore $$ \lim\limits_{R\rightarrow +\infty}iR\int_0^{\frac{\pi}{2}}f(Re^{i\vartheta})e^{i\vartheta}d\vartheta=0 $$ Taking the limit as $R\rightarrow +\infty$ gives that $$ \int_0^{+\infty}f(t)dt=i\int_0^{+\infty}f(it)dt $$ That is $$ \int_0^{+\infty}\frac{e^{it}}{t^{\alpha}}dt=e^{i\frac{\pi}{2}(1-\alpha)}\Gamma(1-\alpha) $$ Taking the imaginary part gives that $$ \int_0^{+\infty}\frac{\sin(t)}{t^{\alpha}}dt=\sin\left(\frac{\pi}{2}(1-\alpha)\right)\Gamma(1-\alpha)=-\cos\left(\frac{\pi\alpha}{2}\right)\alpha\Gamma(-\alpha) $$ We can therefore conclude that $$ \int_0^{+\infty}\frac{1-\cos(x)}{x^{1+\alpha}}dx=-\cos\left(\frac{\pi\alpha}{2}\right)\Gamma(-\alpha) $$ which is the formula given by Hans Olo in the comments section.
Tuvasbien
  • 8,907
  • Inasmuch as $0<\alpha<1$, the expression $\Gamma(-\alpha)$ seems a bit awkward. See my solution, which develops the solution using real analysis only and avoids the Gamma function with negative argument. – Mark Viola Jul 29 '21 at 17:58
  • I don't understand your point, I used $\Gamma(1-\alpha)$ and then after, I changed it to $-\alpha\Gamma(-\alpha)$ to match the expression in the comment. – Tuvasbien Jul 29 '21 at 18:19
  • Yes, your answer is not incorrect. It just seems awkward to express the answer with a Gamma function with negative argument. In fact, the integral of interest exists for $\alpha \in (0,2)$, whereas your answer does not make this obvious since $\Gamma(-1)$ fails to exist. Have a look at my solution including the "NOTE" wherein I show the equality of our results. P.S. Instead of your using the functional equation, you could have used the reflection formula. – Mark Viola Jul 29 '21 at 18:21
  • The gamma function is still on with a negative argument. The awkwardness of the solution is somewhat subjective. – Hans Olo Jul 29 '21 at 18:39
  • @HansOlo What is $\Gamma(-1)$? It doesn't exist. The indeterminate form as $\alpha\to 1$ makes the awkwardness of your form of the solution less subjective, does it not? – Mark Viola Jul 29 '21 at 19:20
  • There is a branch point (or pole when a=1) at the origin. Need we not be careful about that? – mjw Jul 29 '21 at 19:30
  • When $\alpha\rightarrow 1$, $-\cos\left(\frac{\pi\alpha}{2}\right)\sim(1-\alpha)\frac{\pi}{2}$ and $\Gamma(-\alpha)\sim\frac{1}{1-\alpha}$ thus the product converges to $\frac{\pi}{2}$ which is the value of the Dirichlet integral and the singularity is removeable. – Tuvasbien Jul 29 '21 at 19:45
  • @Tuvasbien I believe that I covered this in my posted solution herein. ;-) – Mark Viola Jul 30 '21 at 17:59
  • Both solutions are nice. I just want to add that, if we use complex integration, we also have to add a small quarter-circle around $z=0$ (because this is a singular point). If $\alpha <1$ integral along this small circle $\to0$ at $r\to0$. If $\alpha\in[1;2)$, this integral is non-zero but, due to the fact that it is real, it does not contribute into imaginary part. $\Re\int_0^{+\infty}\frac{e^{it}}{t^{\alpha}}dt$ diverges for $\alpha\in[1;2)$ – Svyatoslav Jul 30 '21 at 18:22
