In
I was able to find out the following. It is for a bigger physics research problem having to do with comparing a Wigner function corresponding to a state of light for the user named @Jayanth Jayakumar. Although, I know almost nothing on this subject, I still find the result very interesting. In case you do not believe the results, here is graphical proof for each step. I would like to support both of us, but I am more interested in finding out a way to significantly simplify the result below:
$$\mathrm{\int_{-x}^x\frac{dx}{\sqrt {1-x^2} e^{bx^2+ax}}=\quad \frac12 \sum_{n=0}^\infty\sum_{m=0}^n\frac{b^ma^{n-m}sgn\left(x^{m+n+1}\right)\left[(-1)^m+(-1)^n\right]B_{x^2}\left(\frac{m+n+1}{2},\frac12\right)}{m!(n-m)!}=\quad \sum_{n=0}^\infty\sum_{m=0}^n\frac{b^ma^{n-m}k^{m+n+1}\left[(-1)^m+(-1)^n\right]\,_2F_1\left(\frac12,\frac{m+n+1}{2}, \frac{m+n+3}{2},k^2\right)}{m!(n-m)!(m+n+1)}=\quad \sum_{n=0}^\infty\sum_{m=0}^n\frac{b^{2m}a^{2(n-m)}sgn\left(x^{2(m+n)+1}\right)B_{x^2}\left(\frac{2(m+n)+1}{2},\frac12\right)}{(2m)!(2(n-m))!-}\quad -\sum_{n=0}^\infty\sum_{m=0}^n\frac{b^{2m+1}a^{2(n-m)}sgn\left(x^{2(m+n)+3}\right)B_{x^2}\left(\frac{2(m+n)+3}{2},\frac12\right)}{(2m+1)!(2(n-m))!}, }$$
For the full area under the function, set $x=\pm1$: $$\mathrm{\int_{-1}^1 \frac{e^{-bx^2-ax}}{\sqrt{1-x^2}}dx=\quad\frac{\sqrt\pi}{2}\sum_{n=0}^\infty\sum_{m=0}^n\frac{b^ma^{n-m}sgn\left(x^{m+n+1}\right)[(-1)^m+(-1)^n]}{m!(n-m)!} \left(\frac{m+n-1}2\right)^{\left(-\frac12\right)},B_1\left(\frac{m+n+1}2,\frac12\right)= B\left(\frac{m+n+1}2,\frac12\right)= \frac{\sqrt\pi\left(\frac{m+n-1}2\right)!}{\left(\frac{m+n}2\right)!}= \sqrt\pi\left(\frac{m+n -1}2\right)^{\left(-\frac12\right)}}$$
This problem uses a double series, the link has a way to turn it into a single sum, Incomplete Beta function properties, hypergeomtric function values, falling factorial $x^{(y)}$ and the Wigner function. An exact solution is needed, so how can one simplify or evaluate this series? I said before, that the special case was a goal, but now the main goal is simplifying the general case or integrating another way. Please correct me and give me feedback!
Here is a single sum solution inspired by @Harry Peter and @James Arathoon. It uses the Lower Incomplete Fox-Wright function and Central Binomial Coefficient:
$$\displaystyle\begin{align}\displaystyle\int_{-t}^t\frac{dx}{\sqrt {1-t^2} e^{bt^2+at}}=\sum _{n=0}^{\infty } \frac{(2 n)! }{2^{2 n} (n!)^2}\sum _{m=0}^{\infty } \frac{a^{2 m} }{(2 m)!} b^{-\big(m+n+\frac{1}{2}\big)} \gamma\left(m+n+\frac{1}{2},bt^2\right)=\\ b^{-\frac12}\sum _{n=0}^{\infty } \binom {2n}n (4b)^{-n}\,_2Ψ^{(\gamma)}_1\left[\,^{\left(1,n+\frac12,bt^2\right),(1,1)}_{\quad \quad (1,2)}\ \frac{a^2}b\right]\end{align}$$
which is super close to this would be closed form of equation $2.27$ in this Korea Science article. If the coefficients of the factorials of $n$ were the same in the denominator and numerator, also for $m$, then we would technically have a closed form.
where $_1\tilde{F}_2$ is a regularized hypergeometric function that for fixed n seems to evaluate to functions in $a$ involving modified Bessel functions of the first kind.
– James Arathoon Jul 24 '21 at 14:14
