Let me start with your second question, since this is probably going to be harder to Google.
The Catalan numbers are well-known to satisfy the following recurrence:
$$ C_n = \sum_{k=1}^{n} C_{k-1}C_{n-k}$$
For instance, your first lattice path interpretation of the Catalan numbers $C_n$ satisfies this by conditioning on the first place after the origin that the paths touch the diagonal. You have to think about that for a minute, but the point is the $k-1$ shows up because to ensure that $k$ is the first time you hit the diagonal, you have to "step out one square" for the steps between the origin and $(k,k)$.
So you can see where that argument takes you. Let $D_n$ be the number of lattice paths that stay strictly above the diagonal except at $(0,0)$ and $(n,n)$ and exactly one other point. So if you want $k$ to be the only time you hit the diagonal, then you have to step out one square on both sides of $(k,k)$:
$$D_n=\sum_{k=1}^{n-1} C_{k-1}C_{n-k-1}$$
By comparing the two RHS, we can clearly see that $D_n=C_{n-1}$.
When you understand this argument, it's straightforward to unwind it into an explicit bijection between the $D_n$-type paths and the Catalan paths of length $2(n-1)$, but I'll leave that to you :)
Your first question has numerous answers on e.g. the Wikipedia page.
The recurrence above can be turned into the product formula that you mention; it is a standard exercise in generating functions and indeed is usually the first solution to a nonlinear recurrence relation that is solved in this way. You can find the details in any decent book on combinatorics, or the first proof on Wikipedia, or on this website: e.g. Simplifying Catalan number recurrence relation.
There are also direct proofs. They are all at least a little tricky, but you can get a sense of what they entail by looking at the other Wikipedia proofs. The way I understand this trickiness is that for your product formula to be an integer, it must be the case that $n+1$ is a divisor of $\binom{2n+1}{n}$. This in turn can be understood as the freeness of a natural cyclic group action; this and a number of similar/related phenomenon in algebraic combinatorics go by the name of "The Cycle Lemma".
In any case, there are many ways in which I think Catalan objects are more naturally quotients of the set of (appropriate) lattice paths, rather than subsets— and so I view the weirdness in these proofs as the same weirdness inherent anytime we work with "distinguished representatives" of equivalence classes, rather than the classes themselves.
(On a brief look I wasn't able to find direct proofs on MSE. Surely they're here; vets feel free to tell us where in the comments ^.^)
