It is well known that we can determine the degree of a polynomial can be found by finding when the differences are the same. i.e. if the second differences are the same, it is a polynomial of the 2nd degree and if the third differences are the same, it is a polynomial of the 3rd degree.
I've noticed that the coefficient of the highest degree in the equation can be determined by looking at the corresponding differences.
I.e. Given:
x y D1y D2y D3y
1 1 -4 12 12
2 -3 8 24 12
3 5 32 36
4 37 68
5 105
D here stands for Delta.
Right away, you can tell the the equation that matches this will be a polynomial of the third degree.
I've found that the relation between the differences for $\ \Delta\ $ 3y will be related to the coefficient such that:
$\ a\ = \frac{\Delta 3y}{3!} $ where $\ a\ $ is the coefficient for $\ x^3\ $ Here this would be a = 2
What I would like to figure out is how to determine the coefficient for $\ x^2\ $.
I know it is possible to create a matrix of equations and solve, but I am curious about a different approach.
My thought was to consider the equation as if it had no $\ x^3\ $ term. So in order to do that I must change the differences as if $\ x^3\ $ wasn't apart of the equation and this would let me extract the $\ x^2\ $ term.
So I calculated out all of the $\ \Delta y\ $ terms using an equation of just $\ 2x^3\ $
x y D1y D2y D3y
1 2 14 24 12
2 16 38 36 12
3 54 74 48
4 128 122
5 250
I found that if I subtracted these values from the ones in the original equation I would be left with a constant second difference of -12 meaning that $\ b = \frac{-12}{2!}\ = -6 $ where b
is the coefficient of $\ x^2\ $
What I can't figure out is a quick way to determine a value of $\ \Delta 2y\ $ for $\ 2x^3\ $ without adding up all of the numbers manually. If I could do this then the process would be much faster and thus this process would be more practical for polynomial equations of very large degrees.
