Theorem: Every separable metric space $(M, d)$ has a countable base
I've glanced over a couple of proofs for this theorem (for example see the one provided here), but I'm still stuck at the following: Why the neighborhood of an arbitrary element of the metric space $M$ (which might not belong to the dense subset) necessarily contains an element of the countably dense subset? Specifically, let $X$ be a countable dense subset of $M$, $z \in M$ and $G \subset M$ be open such that $z \in G$. Then why necessarily at a distance $h$ for which the open ball $B(z, h) \subset G$ does there exist an element $x_k \in X$ such that $d(z, x_k) < h$?
Element inclusion the other way around makes perfect sense to me: If we take the countably dense subset $X$ of $M$ and consider the collection $C = \{B(x, r)\mid x \in X, r \in \mathbb{Q}_{+}\}$ then of course any $z \in M$ is contained in any neighborhood of the elements of $X$ for some radius $r \in \mathbb{Q}_{+}$ (since we can take arbitrarily large/small radius $r$).
Bonus question: I know it is not a pretty proof, but to prove the theorem, could we do the following: i.) order the elements of the countably dense subset $X$ in to the sequence $x_1, x_2,\dots = \left(x_n\right)_{n \in \mathbb{N}}$, ii.) form the collection of neighborhoods $\{B(x_n, n)\mid n \in \mathbb{N}\}$? Since $X$ is dense, there exists an infinite number of elements of the sequence $\left(x_n\right)_{n \in \mathbb{N}}$ in any neighborhood $\delta > 0$. Thus when moving a small distance $\delta > 0$, we necessarily cover all elements of the space $M$.
    What definition of dense are you using? I assume it's not '$X$ is dense in $M$ if every open set $O$ in $M$ contains an element of $X$'. Is it '$X$ is dense in $M$ if $\overline X = M$'? – silver Jun 25 '21 at 15:08
  • @silver I'm under the assumption that $X$ is dense in $M$ if any neighborhood around an element $x \in X$ contains another element $y \in X\setminus {x}$, i.e. all elements of $X$ are limit points of $X$. – Epsilon Away Jun 25 '21 at 15:12
    If you are assuming that $\overline{X}=M$, then remember the characterization of the closure in more general topologies: $z\in M=\overline{X}$ if and only if for every open set $U$ containing $z$ one has $U\cap X\neq \emptyset$. – amnesiac Jun 25 '21 at 15:12
  • @amnesiac I am not assuming that $\overline{X} = M$, at least not explicitly. I am only assuming that i.) $M$ is a metric space $X \subseteq M$ is a countably dense subset. – Epsilon Away Jun 25 '21 at 15:17
    I don't think your definition is correct. According to that definition, ${0}$ would be dense in $\mathbb R$, right? – silver Jun 25 '21 at 15:18
    The definition I'm used to is that every open set in $M$ contains an element of $X$, not vice versa. You may have confused the two -- if you use the above, the step in the proof becomes trivial. It's also easy to prove that it's equivalent to $\overline X = M$. – silver Jun 25 '21 at 15:19
    @silver Yeah you are correct: The terse definition is that: "$E$ is dense in $X$ if every element of $X$ is a limit point of $E$ or a point of $E$ (or both)." I somehow extrapolated what I perceived to be the density of reals/rationals in an interval to a more general setting. The devil is in the details! – Epsilon Away Jun 25 '21 at 15:23
Let $\{x_n\}_{n=1}^{\infty}$ be a dense subset of $(M,d)$. For each $n$, let $\{B_{n,k}\}_{k=1}^{\infty}$ be a countable base at $x_n$. Such a countable base exists at every point in every metric space. Then $\{B_{n,k}\}_{k,n}$ is a countable base for the entire space $(M,d)$. To prove this, pick any point $u\in X$. Given an open set $U$ containing $u$, there exists some $n$ such that $U$ contains an open ball around $x_n$, (because $\{x_n\}$ is dense in $(M,d)$), and consequently it also contains $B_{n,k}$ for sufficiently large $k$, (because $B_{n,k}$ is a local base at $x_n$ and $U$ is open). This proves that $\{B_{n,k}\}_{k,n}$ is a base for $(M,d)$, and it is a countable union of countably many sets, hence countable.
