I have been playing with the series which I had been calling the 'Double Basel problem' for the past couple of hours
$$ \sum_{n=1}^{\infty} \sum_{m=1}^\infty \frac{1}{{n^2 +m^2}}. $$ After wrestling with this for awhile, I managed to generalize a result demonstrated here. This identity is: $$ \sum_{m=1}^{\infty}\frac{1}{x^2+m^2} = \frac{1}{2x}\left[ \pi \coth{\pi x} - \frac{1}{x}\right]. $$ Hence the original series becomes: $$ \sum_{n=1}^{\infty} \frac{1}{2n}\left[\pi \coth{\pi n} - \frac{1}{n} \right]. $$
I have no idea where to go next with this problem. I seriously doubt that this series is convergent; however, I have been unable to prove it.
  1. Can you prove that this series is divergent?
  2. If it converges what is its value?
Thanks so much!
guavas222
  • 554
The series is monotonic in each argument, hence can be bounded below by an integral, of the form:
$$\int_1^\infty\int_1^\infty \frac{1}{x^2+y^2}dxdy=\int_0^{\pi/2}\int_1^\infty \frac{1}{r^2}rdrd\theta=\infty,$$
so the series diverges.
Alex R.
  • 32,771
  • Thanks for this, but the area you are integrating over isn't well preserved in the polar coordinates. Is the divergence still true? – guavas222 Jun 22 '21 at 23:41
  • @guavas222 Changing variable can't turn a divergent integral into a convergent one if the integrand is nonnegative. – Rivers McForge Jun 23 '21 at 00:05
    @guavas222: You can fix that by adapting the limits so you're sure you're integrating over a smaller set to the right: $$\int_1^\infty \int_1^\infty \frac{dxdy}{x^2+y^2} \ge \int_3^\infty \int_{\pi/8}^{3\pi/8} \frac{rd\theta dr}{r^2} = \infty $$ – Troposphere Jun 23 '21 at 00:13
Another proof that the series diverges: $$ \sum_{n=1}^{\infty} \sum_{m=1}^\infty \frac{1}{{n^2 +m^2}} \ge \sum_{n=1}^{\infty} \sum_{m=1}^n \frac{1}{{n^2 +m^2}} \ge \sum_{n=1}^{\infty} \sum_{m=1}^n \frac{1}{{n^2 +n^2}} = \sum_{n=1}^{\infty} \frac1{2n} = \infty. $$
Greg Martin
  • 78,820
Less slick answer: Since $\displaystyle\lim_{x\to\infty}\coth(x)=1$ and since $\coth(x)\geq 1$ for $x\geq 0,$ then
$$\sum_{n=1}^{\infty} \frac{1}{2n}\left[\pi - \frac{1}{n} \right]=\sum_{n=1}^{\infty} \frac{\pi}{2n}-\frac{\pi}{2n^2} \leq \sum_{n=1}^{\infty} \frac{1}{2n}\left[\pi \coth{\pi n} - \frac{1}{n} \right],$$ and so the series diverges as $\sum_{n=1}^{\infty} \frac{\pi}{2n}$ is divergent and $\sum_{n=1}^\infty\frac{\pi}{2n^2}=\frac{\pi^3}{12}.$
