In Problem $3.14$, we prove (a) Hardy's inequality, (b) the condition for equality, and I shall talk about (c), (d) below. Problem $3.15$ is the discrete case of Hardy's inequality. I have asked three related questions in a single post itself, since all of them are related to Hardy's inequality, and none should be too involved.
There are some existing posts on MSE related to these topics, so I shall link them right away and point out that my question is not a duplicate: Post 1, Post 2, Post 3, Post 4.
For the sake of mentioning it, Hardy's inequality is: For $p\in (1,\infty)$, $f\in L^p((0,\infty))$ relative to the Lebesgue measure, and $$F(x) = \frac{1}{x}\int_0^x f(t)\ dt\quad (0 < x < \infty)$$ we have $$\|F\|_p \le \frac{p}{p-1} \|f\|_p$$
Question 1: This is Problem $3.14(c)$ in Rudin's book.
Prove that the constant $p/(p-1)$ cannot be replaced by a smaller one.
In one of the linked posts, there is some discussion on how this is the best constant, but I was unable to follow it. My sense is that it suffices to find a counterexample, i.e. for every constant $\beta$ smaller than $p/(p-1)$, we need a function $f_\beta\in L^p((0,\infty))$ which does not satisfy the required inequality. Why are we complicating things? If I'm thinking right, could someone help me find a counterexample?
Question 2: This appears as Problem $3.14(d)$ of Rudin's book. The author is trying to emphasize that the inequality is not for $p = 1$.
If $f > 0$ and $f\in L^1$, prove that $F\notin L^1$.
I found an example, $f(x) = e^{-x}$. Then $F(x) = \frac{1-e^{-x}}{x}$. $F$'s integral diverges, since the integral of $1/x$ diverges (use limit comparison test for integrals). However, as @David C. Ullrich pointed out, this is not enough.
Question 3: This is Problem $3.15$ in the same book and is the discrete case of Hardy's inequality.
Suppose $\{a_n\}$ is a sequence of positive numbers. Prove that $$\sum_{N=1}^\infty \left(\frac{1}{N} \sum_{n=1}^N a_n \right)^p \le \left(\frac{p}{p-1} \right)^p \sum_{n=1}^\infty a_n^p$$ if $1 < p < \infty$. If $a_n\ge a_{n+1}$, the result can be made to follow from Hardy's inequality. This special case implies the general one.
I took $f = \sum_{n=1}^\infty a_n \mathbf{1}_{[n,n+1]}$. Then $f\in L^p$ only if $\sum_{n=1}^\infty a^p_n < \infty$. If $f\notin L^p$, the inequality is trivial. So let's take $f\in L^p$. Now using Hardy's inequality, we have $\|F\|_p \le \frac{p}{p-1} \|f\|_p$. What is $F$? $$F(x) = \frac{1}{x}\int_0^x \sum_{n=1}^\infty a_n\mathbf{1}_{[n,n+1]}(t)\ dt = \frac{1}{x}\left(\sum_{n=1}^{\lfloor x\rfloor} a_n + (x - \lfloor x\rfloor)a_{\lfloor x\rfloor + 1} \right)$$ How do I proceed?
P.S. I have already solved Problems $3.14(a)$ and $3.14(b)$, i.e. proving Hardy's inequality and showing that equality holds iff $f = 0$ a.e.
