This is Exercise 3.2.10 of Robinson's "A Course in the Theory of Groups (Second Edition)". According to this search and Approach0, it is new to MSE.
The Details:
On page 8, ibid.,
Let $R$ be a commutative ring with identity. Define ${\rm SL}(n, R)$ to be the set of all $n\times n$ matrices over $R$ with determinant equal to $1$. [It is a group under matrix multiplication, called the special linear group of degree $n$ over $R$.]
On page 74, ibid.,
In case $R={\rm GF}(q)$, [we denote ${\rm SL}(n, R)$ by] $${\rm SL}(n, q).$$
On page 28, ibid., the definition of a derived subgroup $G'$ of a group $G$ is the subgroup generated by all commutators $[x,y]=x^{-1}y^{-1}xy$ of $G$.
To explain the title, I use the
Definition: A group $G$ is perfect if $G=G'.$
The Question:
Let $q$ be an odd prime power greater than $3$. Prove that ${\rm SL}(2,q)$ equals its derived subgroup.
Thoughts:
Let $q=p^\ell>3$ for an odd prime $p$.
My first thought was to try out small values of $q$, like $q=7$; here is a GAP experiment:
gap> G:=SL(2,7);
SL(2,7)
gap> Size(G);
336
gap> DG:=DerivedSubgroup(G);
<group of 2x2 matrices over GF(7)>
gap> Size(DG);
336
But nothing came of such considerations, since the groups are seemingly too big for a naïve approach. The next $q$ value is $3^2=9$: the order of ${\rm SL}(2, 9)$ is $720$ according to GAP. The next $q$ value after that is $11$: the order of ${\rm SL}(2, 11)$ is $1320$ according to GAP.
I don't know what I was hoping to see with using GAP.
My linear algebra is a bit rusty.
I guess I should move on like so . . .
Let $S={\rm SL}(2,q)$. Then
$$S=\left\{\begin{pmatrix} a & b \\ c & d\end{pmatrix}\,\middle|\, a,b,c,d\in GF(q), ad-bc=1\right\}.$$
Let $A=\begin{pmatrix} a & b \\ c & d\end{pmatrix}, B=\begin{pmatrix} x & y \\ z & t\end{pmatrix}\in S$. Then $\det(A)=\det(B)=1$. Consider $[A, B]$, a generator of $S'$. We have $[A,B]\in S$ by definition, so, like I used in the GAP code above, we may conclude that $S'\subseteq S.$
What I need to do is show that an arbitrary $\Xi=\begin{pmatrix} \alpha & \beta \\ \gamma & \delta\end{pmatrix}\in S$ is an element of $S'$. This is where I'm stuck.
It is well-known that
$$S'=\displaystyle\bigcap_{T\le S,\\ X\subseteq T}T,$$
where $X=\{[U,V]\in S\mid U,V\in S\}.$ I'm not sure how this helps.
Please help :)
