Let me answer one question at a time, starting from your example, where you have three weights, corresponding to polynomials P(x), Q(x), R(x).
Using only two weights at a time
P(x)Q(x) tells you in how many ways you can weigh something using only P and Q, so:
$$P(x) Q(x) + Q(x) R(x) + R(x)P(x)$$
$$ = (1+x^2+x^4)(1+x^3+x^6) + (1+x^3+x^6)(1+x^4)+ (1+x^2+x^4)(1+x^4)+$$
$$= 2 x^{10} + 2 x^8 + 2 x^7 + 3 x^6 + x^5 + 4 x^4 + 2 x^3 + 2 x^2 + 3$$
solves the problem of counting in many ways you can weigh something using only two weights.
Note though that we are counting the "zero uses" of a weight as well, so you might want to change slightly, according to your real needs.
I want to find what weights
You could just label P,Q,R with three dummy variables a,b,c like that
$$abP(x) Q(x) + bcQ(x) R(x) + caR(x)P(x)$$
$$ = ab(1+x^2+x^4)(1+x^3+x^6) +bc(1+x^3+x^6)(1+x^4) + c a(1+x^2+x^4)(1+x^4) $$
$$ = (ab+bc) x^{10} + (ab+ca) x^8 + (ab+bc) x^7 + (ab+bc+ca) x^6 + ab x^5 + (ab+bc+2ca) x^4 + (ab+bc) x^3 + (ab+ca) x^2 + (ab+bc+ca) $$
I want to see how many times to add that weight
The simplest way is to attach "the dummy variables a,b,c" to the powers inside the polynomials, in order to "count the number of weights" instead of only "the number of grams" (that is counted using the variable x).
So effectively we will use the polynomials
$$A(a, x) = 1+ax^2+a^2x^4$$
$$B(b,x) = 1 + bx^3 + b^2 x^6 $$
$$C(c,x) = 1 + c x^4$$
And the answer to your problem is:
$$A(a,x)B(b,x) + B(b,x)C(c,x) + C(c,x) A(a,x) $$
$$= (1+a x^2+a^2 x^4)(1+bx^3+b^2x^6) +(1+bx^3+b^2x^6)(1+cx^4) + (1+ax^2+a^2x^4)(1+cx^4) $$
$$= (a^2b^2+b^2c^2) x^{10} + (ab^2+ca) x^8 + (a^2b+bc) x^7 + (a^0b^2+b^2c^0+ca) x^6 + ab x^5 + (a^2b^0+b^0c+c^0a^2 + ca^0) x^4 + (a^0b+bc^0) x^3 + (ab^0+c^0a) x^2 + (a^0b^0+b^0c^0+c^0a^0) $$
