Let $f$ be entire, $|f(z)|\leq 3|z|^4+1$ prove $f$ is a polynomial with deggre $\leq 4$
Solution:
$f^{(4)}(z_0)=\frac{4!}{2\pi i} \int_c\frac{f(z)}{(z-z_0)^5}dz$, $\Rightarrow$ $|f^{(4)}(z_0)|\leq \frac{4!}{2\pi i} \int_c |\frac{f(z)}{(z-z_0)^5}|dz \leq \frac{4!}{2\pi i} \int_c \frac{|f(z)|}{|(z-z_0)^5|}dz \leq$ $$\leq \frac{4!}{2\pi i} \int_{0}^{2\pi}\frac{|f(z_0+re^{it})ire^{it}|}{|(re^{it})^5|}dt \leq \frac{4!}{2\pi i} \int_{0}^{2\pi}\frac{(3(|z_0|+r)^4+1)r}{r^5}dt \leq \frac{4!}{2\pi i} 2\pi\frac{(3(|z_0|+r)^4+1)}{r^4}$$
that means $f^{(4)}(z)$ is bounded so from Liouville's theorem its constant and therefore $f$ is a polynomial with deggre $\leq 4$
Is my solution correct ?
領域展開
  • 2,139
  • Math.se is a Q&A site... – vitamin d May 19 '21 at 16:22
  • That means I can't ask if my solution is correct or not ? – 領域展開 May 19 '21 at 16:23
  • I don't write it maybe I should(I will edit it now), but I think its implied – 領域展開 May 19 '21 at 16:25
    Is this different from your previous question https://math.stackexchange.com/q/4143191/42969 ? – Martin R May 19 '21 at 16:26
  • I just need a yes or no answer. – 領域展開 May 19 '21 at 16:40
  • @MartinR Can we have these merged in a similar way to the merger of yesterday's duplicates? – Mark Viola May 19 '21 at 16:44
  • @MarkViola: Only moderators can merge threads. As I understand it, that is not often done, and only if both threads have good answers. That is not the case here. – However, since you voted this question as a duplicate of an older one, it would have been better (IMO) to answer the older question. – Martin R May 19 '21 at 16:52
  • @MartinR I had not seen the older question existed until after I posted this solution and then saw your comment. This happened yesterday and I was admonished to not post on both pages. So, I could delete my answer herein and post it on the other page. – Mark Viola May 19 '21 at 16:58
Your solution is almost correct. There are a few minor errata. Note that
$$f^{(4)}(z)=\frac{4!}{2\pi i}\oint_C \frac{f(w)}{(w-z)^5}\,dw$$
where $C$ is a rectifiable closed contour that encloses the point $z$.
We may choose $C$ to be the circular contour $|w-z|=r$. Then, we have
$$\begin{align} |f^{(4)}(z)|&=\left|\frac{4!}{2\pi i}\oint_C \frac{f(w)}{(w-z)^5}\,dw\right|\\\\ &\le \frac{4!}{2\pi \color{red}{\underbrace{|i|}_{=1}}}\left|\int_0^{2\pi } \frac{|f(z+re^{i\phi})|}{|r|^5}|\color{red}{\underbrace{ire^{i\phi}}_{=r}}|\,d\phi\right|\\\\ &\le\frac{4!}{r^4}\max_{\phi}|f(z+re^{i\phi})|\\\\ &\le \frac{4!(3\max_{\phi}(|z+re^{i\phi}|^4)+1)}{r^4}\\\\ &=\frac{4!(3(r+|z|)^4+1)}{r^4} \end{align}$$
Letting $r\to \infty$ shows that
$$|f^{(4)}(z)|\le 72$$
whereby appealing to Liousville's Theorem implies that $f^{(4)}(z)$ is constant from which we conclude that $f(z)$ is a polynomial of order $4$.
Mark Viola
  • 179,405
