I'm trying to reconcile the definition of surface area defined using manifolds vs the classic formula in $\mathbb{R^3}$, but it seems like I'm off by a square.
In Spivak's Calculus on Manifolds, the surface area is defined as $\int_M dA$ where $dA$ is a 2 form, namely$dA = n_1 dy \wedge dz + n_2 dz \wedge dx + n_3 dx \wedge dy$, and $n= (n_1, n_2, n_3) $ is the outward pointing normal. You compute the integral of the manifold by "pulling" the 2 form back to the parameterization coordinates.
The "classic formula" I'm referring to is $Area = \int_s |\frac{\partial G}{\partial u} \times \frac{\partial G}{\partial v}| dA$ where $G(u,v)$ is a parameterization of the surface, and $dA$ means $du dv$ (not to be confused with the definition above). This formula can be found at the bottom of this page: https://tutorial.math.lamar.edu/Classes/CalcIII/ParametricSurfaces.aspx
The problem is, for a simple surface like a sphere, and other surface I've tried, I'm always off by a square. Here is the attempt to find the surface area of a unit sphere using both methods:
Parameterizing with $G(\theta, \phi) = (\cos \theta \sin \phi, \sin \theta \sin \phi, \cos \phi)$ for $\theta \in [0, 2\pi]$ and$\phi \in [0, \pi]$ we calculate: $$dx = -\sin\theta \sin \phi d\theta + \cos \theta \cos \phi d\phi$$ $$dy = \cos \theta \sin d \theta + \sin \theta \cos \phi d \phi$$ $$dz = -\sin \phi d\phi$$
Therefore $$dx \wedge dy = - \sin \phi \cos \phi d \theta d\phi$$ $$dz \wedge dx = - \sin \theta \sin^2 \phi d\theta d \phi$$ $$ dy \wedge dz = - \cos \theta \sin ^2 \phi d \theta d \phi$$
The normal $n$ is calculated to be:
$$n_1 = - \cos \theta \sin ^2 \phi$$ $$n_2 = - \sin \theta \sin^2 \phi $$ $$n_3 = - \sin \phi \cos \phi $$
$n_3$ just happens to be identical to the coefficient function of $dx \wedge dy$.
$n_2$ just happens to be identical to the coefficient function of $dz \wedge dx$.
$n_1$ just happens to be identical to the coefficient function of $dy \wedge dz$.
So then $\int_M dA = \int_{[0,\pi] \times [0,2\pi]} G^*(dA) = \int_0^{\pi} \int_{0}^{2\pi} (\sin^2 \phi \cos^2 \phi + \sin^2 \theta \sin^4 \phi + \cos^2 \theta \sin ^4 \phi )d \theta d\phi $.
This result is off by a square. The "classic formula" has an additional square root since we're taking the norm of $\frac{\partial G}{\partial u} \times \frac{\partial G}{\partial v}$. So under the classic formula $Area = \int_s |\frac{\partial G}{\partial u} \times \frac{\partial G}{\partial v}| dA = \int_0^{\pi} \int_{0}^{2\pi} \sqrt{\sin^2 \phi \cos^2 \phi + \sin^2 \theta \sin^4 \phi + \cos^2 \theta \sin ^4 \phi} d \theta d\phi$.
The solution with the square root is correct. What am I doing incorrectly with respect to the manifold method?
