Consider the differential equation $ y'(x)=f(x,y(x)) $ with initial condition $y(x_0)=y_0$. According to some theorem, if $f$ is continuous, then there exists at least one solution that satisfies the initial condition. If $f $ is also continuously differentiable, then the solution is unique.
So my question is, does $f$ really have to be continuously differentiable? Intuitively I could calculate the values of $y$ by using the approximation formula $$ y(x_0+\Delta x) \approx y'(x_0)\Delta x+y(x_0) =f(x_0, y_0)\Delta x+y_0 $$ for very small $ \Delta x $. Isn't this the idea behind Euler's method? And this technique leads to unique solution, right? And therefore we would not have any requirements for $f $ expect for being defined on every point of some interval.
