I am trying to prove the claim in Remark 1.2.13. : enter image description here which I can if I can prove the two following which I don't know how to prove them:
1- If $T$ is a measurable transformation and B a measurable set then $T[B]$ is a measurable set?
2- If $T$ is an invertible measurable transformation $T^{-1}$ is a measurable transformation too?
If any one of the two questions wrong, then I would need another proof for the mentioned remark in the text.
Please help. Thanks!
Alp Uzman
  • 10,742
  • My question is to prove the claim of the remark 1.2.13 in the book ... –  Mar 31 '21 at 19:07
In all of the Ergodic books I've seen, it is assumed that the definition of invertible means that the inverse is measurable.
In general, this need not be the case. Let $T(x)=2x\,\text{mod} 1$ and $X=[0,1)$ equipped with Lebesgue measure. This map is measure preserving, but it's inverse is not. To see that $T(x)$ is measure preserving, let $B\subset [0,1)$ be some measurable set, which can be assumed to be an interval of the form $(a,b)$. To see that $T(x)$ is a measure preserving transformation, we have the following calculation: \begin{equation} \begin{split} &\mu(T^{-1}\big{(}(a,b)\big{)}\\ &=\mu\Big{(}\big{(}\frac{a}{2}, \frac{b}{2}\big{)}\bigcup\big{(}\frac{a+1}{2}, \frac{b+1}{2}\big{)}\Big{)}\\ &=\mu((a,b)) \end{split} \end{equation} If the above calculation isn't obvious to you. Here are some concrete examples.
Suppose that $(a,b)=(0,1)$: \begin{equation} \begin{split} T^{-1}\big{(}(a,b)\big{)}&=T^{-1}\big{(}(0,1)\big{)}\\ &=\big{(}0,\frac{1}{2}\big{)}\cup\big{(}\frac{1}{2},1\big{)}. \end{split} \end{equation}
Additionally, suppose that $(a,b)=(0, \frac{1}{2})$: \begin{equation} \begin{split} T^{-1}\big{(}(a,b)\big{)}&=T^{-1}\big{(}(0,\frac{1}{2})\big{)}\\ &=\big{(}0,\frac{1}{4}\big{)}\cup\big{(}\frac{1}{2},\frac{3}{4}\big{)}. \end{split} \end{equation} Hence, $T^{-1}\big{(}(a,b)\big{)}$ is a pair of two non-overlapping intervals, which preserves measure.
Conversely for the inverse, note that if $B=[0,\frac{1}{2})$, then ${(T^{-1})}^{-1}(B)=T(B)=[0,1)$, so the measures are different. Also note that the above example generalizes to $T(x)=nx\,\text{mod} 1$ for $n$ being any positive natural number.
    Expanding maps are not bijections. If you extend the system to the solenoid it becomes a bijection, in which case the inverse is also measure preserving. – Alp Uzman Mar 31 '21 at 15:33
In general it is not true that bijective measurable maps are bimeasurable, see Measurability of the inverse of a measurable function. There it is shown that bijective measurable absolutely continuous maps are bimeasurable.
So let us let an invertible measure preserving transformation $f$ of a probability space $(X,\mu)$ stand for a bimeasurable bijection that preserves $\mu$ (which then implies the inverse also preserves $\mu$, as the Remark remarks).
Let me also mention that it is not uncommon to have all this be applicable $\mu$-almost everywhere, so that there are $\mu$-full measure sets $X_1,X_2\subseteq X$ such that $f:X_1\to X$ is measurable and measure preserving, $g:X_2\to X$ is measurable and measure preserving, $g\circ f = \operatorname{id}_{X_1}$, $f\circ g = \operatorname{id}_{X_2}$ (Here $g$ is $f^{-1}$ measure theoretically). A standard example is the isomorphism (in the category of measure-spaces and measure-preserving measurable maps) between the sequence space $F(\mathbb{Z}_{\geq0},\{0,1\})$ and the standard Cantor set.
Alp Uzman
  • 10,742
  • Does a measure preserving bijection have a measurable inverse? I think this is more relevant for OP's question. – Andrew McMillan Mar 31 '21 at 15:58
  • One would need absolute continuity. For the backward map to be measure preserving the forward map ought to not create measure out of nothing. – Alp Uzman Mar 31 '21 at 16:02
  • Ok. Can you give an example of a measure preserving bijection that has no measurable inverse? I am having a hard time thinking of one! – Andrew McMillan Mar 31 '21 at 16:04
  • Me too. I have some ideas but I'll hold onto them for now. It may very well be that your exclamation mark is well warranted. – Alp Uzman Mar 31 '21 at 17:21
  • So the q.2 is solved by assuming inverse to be measurable, and about q.1 I searched a lot but I think image of a measurable set under a measurable map need not be a measurable set (?) So the equivalence claimed in the remark of the book is valid? –  Mar 31 '21 at 19:08
  • q.1 and q.2 are equivalent. The remark is certainly false in general, but frequently, as both Alp Uzman and I commented, the dynamics literature defines invertible to mean that the inverse is measurable. – Andrew McMillan Mar 31 '21 at 20:07
  • @AndrewMcMillan, ok, thanks! –  Mar 31 '21 at 20:08
