-2
How do I evaluate the power series $$\sum_{n = 1}^{\infty}\dfrac{n}{9^{n}}$$ without using the formula for infinite geometric series?
I am interested in an approach which doesn't make use of infinite geometric series.
Any help would be highly appreciated. New approaches are most welcomed. Thanks.
I'm not sure about the exact value, but you can compare it to the integral, which converges since $|\frac{1}{9}|<1$, $\int_{0}^{\infty}x a^x dx$, which will be of the same order, and then derive the difference using Bernoulli polynomials.
Alex
  • 19,262
Check with induction that the partial sum is $$\sum_{k=1}^N \frac{k}{9^k} = \frac{9 - 9^{-N}(8N+9)}{64}$$ Evaluate the limit when $N$ goes to infinity and you get the result.
Gabrielek
  • 1,898
  • This approach rather seems to be very naive – BooleanCoder Mar 22 '21 at 11:44
    Just to be honest, as @DavidMitra pointed out in the reference, there is a known formula for partial sums of series like this, and this result is derived using "geometric series results". However you could pretend to be blind and use induction on a formula that comes from heaven and you are done lol. – Gabrielek Mar 22 '21 at 11:47
  • lmao Thanks anyways – BooleanCoder Mar 22 '21 at 11:49
Notice that $x \frac{d}{dx} \frac{1}{1-x} = \sum_{i=0}^{\infty}ix^i $. So differenciating you get $$x \frac{d}{dx} \frac{1}{1-x} = \frac{x}{(1-x)^2}$$ Substituting $x= \frac{1}{9}$ you get required answer.
Strange
  • 737
    How is this not using the geometric series? Don't you need to know in advance that $\frac 1{1-x}=\sum_{i\geq 0} x^i$? – Giulio R Mar 22 '21 at 11:48
  • Yeah this does uses geometric series :( – Permutator Mar 22 '21 at 11:51
  • Well you can compute derivatives in zero...however not complete, but in general I do not see why one should restrain from using a basic identity such as the geometric series to use more involved methods (you also need to prove that your convergence radius of the Taylor expansion is greater than $1/9$ which involves study of analytic functions...) – Giulio R Mar 22 '21 at 11:53
Denote $A=\sum_{n\geq 1} n9^{-n}$, $B=\sum_{n\geq 2} n9^{-n}$, $C=\sum_{n\geq 1} 9^{-n}$, $D=\sum_{n\geq 2} 9^{-n}$. You have the closed system $$ A=B+\frac 19,\quad 9B-A=C,\quad C=D+\frac 19,\quad 9D=C, $$ which gives the value of $A$. Of course, as a byproduct of the computation one also gets the value of the geometric series $C$.
Giulio R
  • 3,216
