I am trying to show that when you multiply $$G(t,\textbf{r}) = -\frac{1}{4\pi r}\delta(t-\frac{r}{c}) $$ by the d'Alembertian you get $$\square G = \delta(t)\delta(\textbf{r})$$ and immensely struggling, so any help would be much appreciated!
I have been trying to answer your question since you posted it, this is my current state now. Not yet an answer! Maybe this helps you move forward while i struggle.
$$\nabla f(x-x')=\left(\partial_xf,\partial_yf,\partial_zf\right)=f'(x-x')$$
$$\square G(x-x')=\delta(x-x') $$
$$\phi=\delta(x-x_0,y-y_0)$$
This is the distribution sending $f$ to $f(x_0,y_0)$
$$\phi(f)=f(x_0,y_0)$$
rule: https://math.stackexchange.com/a/1413826/738388
$$\langle f,\delta'_a\rangle=-\langle f',\delta_a\rangle=-f'(a)$$
$$(\delta')(f)=-\delta(f')=-f'(0)$$
$$\frac{d\phi}{dx}(f)=\frac{d}{dx}\delta(x-x_0,y-y_0)(f)=-\delta(x-x_0,y-y_0)(f')=-\frac{d}{dx}f(x_0,y_0))$$
https://math.stackexchange.com/a/445092/738388
$$\langle\nabla f,\cdot\rangle=df$$
$$\nabla\phi=\frac{d\phi}{dx}dx+\frac{d\phi}{dy}dy$$
where $dx$ and $dy$ are differentials
$$\vec{\nabla}_x \delta^{(3)}(\vec{x}-\vec{x}')=-\vec{\nabla}_{x'} \delta^{(3)}(\vec{x}-\vec{x}').$$
where $\delta^{(3)}$ is the generalized 3 dimensional Dirac-delta. Source https://www.physicsforums.com/threads/gradient-of-dirac-delta.880397/
Lord Commander
  • 904
You seem to be missing a derivative. Since by the chain rule$$\partial_if(r)=\frac{1}{2r}\partial_i(r^2)f^\prime(r)=\frac{x_i}{r}f^\prime\implies\nabla f=\vec{e}_rf^\prime$$for radially symmetric $f$ (in this case $f$ is a distributional measure rather than a function), the final result follows from another application of the chain rule, which gives the $-\tfrac1c$ factor.
J.G.
  • 115,835
