The matrix is of type: linear combination of the identity and a rank $1$ matrix, the latter being the matrix all of whose entries are $-b$, call it $B$. Then $B$ is easily diagonalisable, with an $n-1$ dimensional kernel (eigenspace for $0$) given by the equation $x_1+\dots+x_n=0$, and a $1$ dimensional other eigenspace, spanned by $(1,1,\ldots,1)$, whose eigenvalue for $B$ equals $-nb$. We have $A=B+(a+b)I_n$; the eigenspaces of $B$ are also eigenspaces for $A$, but with eigenvalues $\lambda=a+b$ respectively $\mu=-nb+a+b=a+(1-n)b$.
The linear problem is easy to solve on each eigenspace: on the $n-1$ dimensional eigenspace $A$ acts by multiplication by $\lambda$ and, provided $\lambda\neq0$, the solution will be $X=\frac1\lambda Y$, while on the $1$-dimensional eigenspace $A$ acts by multiplication by $\lambda$ and, provided $\mu\neq0$, the solution will be $X=\frac1\mu Y$. For the general solution one can decompose $Y$ into its projections $Y_1$ and $Y_2$ on the two eigenspaces, and provided both $\lambda=a+b$ and $\mu=a+(1-n)b$ are nonzero one can find the solution by adding the solutions associated to $Y_1$ and $Y_2$. One has $Y_2=\frac{(y_1+\cdots+y_n)}n(1,1,\ldots,1)$ and $Y_1=Y-Y_2$; the general solution then is $X=\frac1\lambda Y_1+\frac1\mu Y_2$. Working this out explicitly is a bit messy, but straightforward.
Here is a concrete example if you find this too abstract. Take $n=5$, $a=2$ and $b=1$. Then neither $\lambda=a+b=3$ nor $\mu=a+(1-n)b=-2$ is zero, so the problem is solvable for all $Y$. Take for instance $Y=(3,-1,2,5,-4)$, it decomposes as the sum of a multiple $Y_2$ of $(1,1,1,1,1)$ by the scalar $\frac{3-1+2+5-4}5=1$, and a vector $Y_1=Y-Y_2=(2,-2,1,4,-5)$ whose sum of coordinates is $0$. The solution for $X$ then is
$\frac1\lambda Y_1+\frac1\mu Y_2=\frac13(2,-2,1,4,-5)-\frac12(1,1,1,1,1)=\frac16(1,-7,-1,5,-13)$.
