Given a very simple linear projection model $Y=X\beta+e$ with $E(e|X)=0$ and $X$ a scalar. Notice that this is a simple linear model with no intercept.
Then $\beta = E(XY)/E(X^2)$ from the least squares formula.
On the other hand, if I take expectation on both sides of the original model, I get $E(Y)=\beta E(X)+E(e)=\beta E(X)$. Therefore, $\beta=E(Y)/E(X)$. (Of course, suppose $E(X)\neq 0$.)
I just don't see how the two quantities could be identical. Did I do something wrong?
Bunbury
  • 395
  • If the model were to assume a non-zero intercept, $\alpha$, then the OLS regression results in a estimate for $\alpha$ given by $$\hat \alpha =E(Y)-\hat \beta E(X)$$From this, note that a zero value of $\hat \alpha$ would correspond with an estimate for $\beta$ given by $$\hat \beta =E(Y)/E(X)$$ So, this is consistent with your result. – Mark Viola Feb 10 '21 at 15:46
$E[f(X)Y]=E[f(X)X]\beta+E[f(X)e]=E[f(X)X]\beta$, so $\beta=\frac{E[f(X)Y]}{E[f(X)X]}=\frac{E[Y]}{E[X]}=E[\frac{Y}{X}]=E[\frac{f(X)}{E[f(X)]}\frac{Y}{X}]$ ...
Strange ...
Ian Zhang
