Let $f$ and $g$ be two entire functions, s.t. $|f(z)|\leq |g(z)|$ $\forall z \in \Bbb C$. I wanna show that it exists $\lambda \in \Bbb C$, with $|\lambda |\leq 1$ so that $f(z)= \lambda \cdot g(z)$ $\forall z \in \Bbb C$.
Let's observe $h:= \frac{f}{g}$, with $g$ not equal to zero. By assumption $\vert h \vert \leq 1$ so all the singularities of h, which are isolated by the identity principle, are removable by the Riemann extension theorem.
Why can we conclude this?
As pointed out in the comments, either $g$ vanishes identically (and in this case the conclusion is trivial, since both $g$ and $f$ are $0$) or it has isolated zeroes.
In the latter case, the quotient $h$ is in modulus $\le1$ and defines an holomorphic function on the whole plane minus a discrete set (the zeros of $g$). By Riemann thm, as pointed out, $h$ extends across these isolated singularities to an entire function which is then bounded. Then by Liouville theorem $h$ is constant, that is, $\exists \lambda\in\Bbb C$ such that $0<|\lambda|\le1$ such that $h\equiv\lambda$. Since $h=f/g$ you get the conclusion.
Joe
  • 11,745
