Consider the following question:
(a) The following conditions on a field K are equivalent :So, Prove them
(i) every irreducible polynomial in K[x] is separable ;
(ii) every algebraic closure K of K is Galois over K;
(iii) every algebraic extension field of K is separable over K;
(iv) either char K = 0 or char K = p and $K = K^p$.
(i)=>(ii) This part I am not able to do. What i am missing is how to prove that for all $\sigma \in Aut_K{\bar K}$ only y$\in K$ gets fixed and rest all are not fixed.
(ii)=> (iii) I have done as if an algebraic extension is galois over K and then the extension is also separable over K ( This is a theorem).
(iii)=>(iv) I tried by assuming that char K $\neq 0$, so, As field is integral domain, so Characterstic must be prime and so, let char K=p but then I am not able to move towards proving $K=K^{p}$.
(iv)=>(i) I have solved . So, I don't require help with that.
Kindly shed some light on this
For (i)=>(ii): Let $L$ be an algebraic closure of $K$. Then $L/K$ is by definition normal and by assumption separable. Depending on your definition of Galois-extension we might be done here. If your definition of Galois extension is $K=L^{Aut_KL}$, then look at the answer to one of your previous questions.
For (iii)=>(iv): If $a\in K$ there is some $b\in L$ in an extension field with $b^p=a$. Now look at the irreducible factors (over $K$) of the polynomial $x^p-a=(x-b)^p$ and use your assumption.
leoli1
  • 6,979
  • 36
  • Why is in $(iii) \to (iv) $ there exists some $b\in L$ in an extension field with $b^p =a$? can you please tell? –  Oct 17 '21 at 06:17
