Solve $(1 + x)y' = py;\ \ \ y(0) = 1$, where $p$ is an arbitrary constant.
First I plugged in the guess $y = \sum_{n = 0}^\infty a_n x^n$:
$(1 + x)(\sum_{n = 0}^\infty a_n x^n)' = p\sum_{n = 0}^\infty a_n x^n$
Then I expanded the derivative and multiplication:
$\sum_{n = 0}^\infty n a_n x^{n - 1} + \sum_{n = 0}^\infty n a_n x^n = p\sum_{n = 0}^\infty a_n x^n$
Then I shifted the left index (the first term yielding $0$ allows the lower bound to remain $0$) and algebraically combined the summations:
$\sum_{n = 0}^\infty (n + 1)a_{n + 1} x^n + (n - p)a_n x^n = 0$
This leads to the following recurrence relation:
$a_{n + 1} = \frac{p - n}{n + 1}a_n$
Thus for various values of $n$:
$a_1 = p a_0$, $a_2 = \frac{p(p - 1)}{2}a_0$, $a_3 = \frac{p(p - 1)(p - 2)}{6} a_0$, etc.
So applying definitions for the exponential taylor series and falling factorial, the guessed solution would be:
$y = \sum_{n = 0}^\infty \frac{p! a_0 x^n}{n! (p - n)!} = \sum_{n = 0}^\infty a_0 e^x p^{\underline n}$
Solving the initial value problem:
$1 = \sum_{n = 0}^\infty a_0 e^0 p^{\underline n} \implies a_0 = \frac{1}{\sum_{n = 0}^\infty p^{\underline n}}$
My final solution is:
$y = \frac{\sum_{n = 0}^\infty e^x p^{\underline n}}{\sum_{n = 0}^\infty p^{\underline n}}$
However, the answer is supposed to be $y = (1 + x)^p$. Are these identical, or did I make an error somewhere?
