I need to solve a rather simple optimization problem, however the structure of the problem makes out-of-the-box commercial solvers fail. The problem is:\begin{aligned} &\min_{x_i}\|\sum_{i=1}^{10}x_i\mathbf{a}_i - \mathbf{b}\|_2^2 \\ &s.t.: \sum_{i=1}^{10}x_i = 1,\; x_i\geq0 \end{aligned} The decision variables are $x_i$, which are scalars, and typically the problem will have 10 variables. The complexity comes from the fact that $\mathbf{a}_i, \mathbf{b}$ are VERY LONG constant vectors, varying from 10,000 to 100,000 elements and possibly more. Without going too much into details, black-box solvers fail since they impute the variable over vectors, thus converting a 10-D problem to 100K-vars problem.
Since the problem has a simple structure (only complicated by the constant vectors), I think that interior point algorithms can perform well here. Also, the Hessian is very simple and easy to compute - it's $ij$-th entry is simply $\langle \mathbf{a}_i, \mathbf{a}_j \rangle$, with size $10\times 10$. I'm very familiar with optimization, however my experience is mostly with first-order algorithms. I'm almost clueless when it come to IPMs and not sure how to implement an appropriate algorithm. Does anyhow have a ready script I can use? Or any other tips that might help?
