In the text
    Nicholson -- Introduction to Abstract Algebra, 4th Ed (2012)
the claim of exercise $8(b)$ of exercise set $11.1$ is:
    If $R$ is a left artinian ring with $1\ne 0$, and $M$ is a finitely generated left $R$-module such that $\text{ann}(M)=0$, then $M$ has a submodule isomorphic to $R$.
But in my answer to
$\;\;\;\;\;$ How to show $\operatorname{ann}(M) = \operatorname{ann}(X)$.
I gave a counterexample to the above claim.
I wonder if the claim could be repaired by assuming as an additional hypothesis that $R$ is commutative.
Question:
    If $R$ is a commutative artinian ring with $1\ne 0$, and $M$ is a finitely generated $R$-module such that $\text{ann}(M)=0$, must $M$ have a submodule isomorphic to $R$?
Two special cases: The answer is "yes" if
  • $R$ is a field.$\\[4pt]$
  • $R$ is finite.
That's as far as I've got.
user26857
  • 52,094
quasi
  • 58,772
  • Does this help you? https://math.stackexchange.com/a/3187153/164860. Here $R$ is a commutative Artinian ring, $M$ is a faithful $2$-generated $R$-module, and every element of $M$ has nonzero annihilator. Thus $M$ can't have a submodule isomorphic to $R$. Note that another special case where the answer is "yes" is if $R$ is any reduced Noetherian ring, see e.g. https://math.stackexchange.com/questions/1269660/annihilators-of-elements-of-a-finitely-generated-faithful-module-over-a-noetheri – Badam Baplan Dec 25 '20 at 23:32
  • @Badam Baplan: Thanks for the reference, and yes, the example given in the accepted answer in that link appears to give an answer of "no" to my question. Thanks again. Should I now delete my question? – quasi Dec 25 '20 at 23:59
  • Hmm.. I think it's a worthwhile question to keep searchable because it addresses an error in a textbook and points to a useful counterexample (I think it is valuable to reinforce good mse posts by linking to them). Perhaps you could write up a short answer to your own question and accept it. – Badam Baplan Dec 26 '20 at 00:05
  • I took the liberty of editing the title to make it more specific / searchable. – Badam Baplan Dec 26 '20 at 00:07
    @Badam Baplan: I'll leave it for you or someone else to answer. Thanks again. – quasi Dec 26 '20 at 00:09
Wow, that is an unfortunate mistake you found.
For semiperfect rings, there is a notion of the basic module of the ring, which is a faithful module that captures a lot about the ring. This is a theorem:
If $R$ is a semiperfect ring, then right basic module is a summand of any generator of Mod-$R$.
For a commutative Artinian ring, the basic module is just $R$ itself. But the missing ingredient, as you see, is that a faithful module need not be a generator of Mod-$R$. A ring for which every faithful f.g. module is a generator of Mod-$R$ is called finitely pseudo-Frobenius. So the best you can say, I think is
If $R$ is a commutative, semiperfect, finitely pseudo-Frobenius ring, then $R$ is a summand of every f.g. faithful module.
The nicest class for which this is all true is commutative quasi-Frobenius rings.
rschwieb
  • 153,510
