How many "$1$" is need at least for a decimal number,which is consisting of "$0$" and "$1$" and divisible by $p$?
If $p=2^k\cdot d+1$, and $10^d\equiv 1 \pmod p$,then $10^n\equiv -1 \pmod p$ has no solution, so $10^n+1$ is never divisible by $p$, so two "$1$" is not enough,but since $\dfrac{10^{p-1}-1}{9}=11\cdots 111\equiv 0 \pmod p$,so $p-1$ is awlays enough,in fact,$ord(10,p)$ is enough,but may be not the least.
In When is it solvable:$10^a+10^b\equiv -1 \pmod p$ , I asked that when three "$1$" is need at least,I think I should ask this original problem here,because this is more general and why I asked that question.
Assume $(10,p)=1.$
Two "$1$" is need at least for $p=7, 11, 13, 17, 19, 23, 29, 47, 59, 61, 73, 89, 97, 101, 103,\cdots$
Three "$1$" is need at least for $p=3, 31, 37, 43, 53, 67, 71, 83, 107, 151, 163, 173, 191, 199,\cdots$
Four "$1$" is need at least for $p=79, 733,\cdots$
Thank you!
lsr314
  • 15,806
  • Related http://math.stackexchange.com/questions/164986/smallest-multiple-whose-digits-are-only-ones-and-zeros or http://math.stackexchange.com/questions/233746/existance-of-multiple-of-n-with-only-0-and-1-as-its-digits ? – lab bhattacharjee May 19 '13 at 07:14
  • @lab bhattacharjee Thank you for the links!But they are both different to this, my question is how to find the least number of "$1$",neither to find the least number which is divisible by p,nor to prove that there is such a number.I think this problem to more worth to consider,because we can answer it easily whether two "1" is need at least. – lsr314 May 19 '13 at 07:22
  • If the number must end in "$1$" then $2$ is impossible, otherwise $2$ and $5$ only need one "$1$". – WimC May 19 '13 at 07:25
  • @WimC we only consider the case $(10,p)=1$,I said it in another my question..Thanks for your suggest,I will edit it. – lsr314 May 19 '13 at 07:27
