Currently, I am going through Tom Apostol's "Calculus: Volume 1 Second Edition" as I heard this was a good book to get a solid understanding of calculus and I wasn't satisfied with James Stewart's 9th edition calculus book.
I am on page 6 of the book and I am having some trouble. On pages 5 and 6, Apostol is proving that the area under the curve of $y = x^2$ between $x = 0$ and $x = b$ is equal to $\frac{b^3}3$, or $\frac{1}3$ of a rectangle with a base of length $b$ and a height of $b^2$. After proving that $1^2 + 2^2 +...+(n-1)^2 = $ $\frac{n^3}3 +$ $\frac{n^2}2 + $ $\frac{n}6$ (although I didn't fully understand how Apostol proved that either, this video by blackpenredpen https://www.youtube.com/watch?v=OpA7oNmHobM&ab_channel=blackpenredpen cleared that up for me so if anyone has trouble with that, check the link out), Apostol goes on to say:
For our purposes, we do not need the exact expressions given in the right-hand members of (I.3) and (I.4), or they can be proved directly by induction. (A proof by induction is given in Section I 4.1.)
All we need are the two inequalities
$1^2 + 2^2 + ... + (n-1)^2$ < $\frac{n^3}3$ < $1^2 + 2^2 + ... + n^2$
which are valid for every integer n $\geq$ 1. These inequalities can be deduced easily as consequences of (I.3) and (I.4), or they can be proved by induction. (A proof by induction is given in Section I 4.1.)
If we multiply both inequalities in (I.5.) by $\frac{b^3}{n^3}$ and make use of (I.1) and (I.2), we obtain
$s_n$ < $\frac{b^3}3$ < $S_n$
for every n. The inequalities in (1.6) tell us that $\frac{b^3}3$ is a number which lies between $s_n$ and $S_n$ for every n. We will now prove that $\frac{b^3}3$ is the only number which has this property. In other words, we assert that if A is any number which satisfies the inequalities
$s_n$ < A < $S_n$
for every positive integer n, then A = $\frac{b^3}3$. It is because of this fact that Archimedes concluded that the area of the parabolic segment is $\frac{b^3}3$.
My questions arises at the inequality: $1^2 + 2^2 + ... + (n-1)^2$ < $\frac{n^3}3$ < $1^2 + 2^2 + ... + n^2$
I understand that the values less than $\frac{n^3}3$ are the sum of squares of the heights of rectangles under the parabolic segment where $y=x^2$ and the values greater than $\frac{n^3}3$ are the sum of squares of the heights of rectangles that extend beyond the parabolic segment where $y=x^2$.
My question is, how did Apostol come up with the idea to use $\frac{n^3}3$ in the inequality?
I have looked to this link Method of Exhaustion applied to Parabolic Segment in Apostol's Calculus before I asked this question as this was the closest I found to someone asking a similar question but I could not find the answer.
For context, I have provided images of pages 1 through 8 so I can show you all that Apostol is doing for this proof.
Also, sorry for any formatting errors as this is my first time posting on this site.
Images:
Pages 1 and 2
Pages 3 and 4
Pages 5 and 6
Pages 7 and 8
  • Well, he knows what the answer is. – saulspatz Dec 05 '20 at 00:59
  • "how did Apostol come up with the idea to use $\frac{n^3}3$ in the inequality?" I strongly suspect that he didn't originate the idea. Calculus probably evolved through centuries of blind research down mostly dead-end allies. Over the centuries, at or before the development of Calculus in the 1600's on, some mathematician came up with the idea. The situation was perhaps a hybrid of idea born of talent combined with intellectually winning the lotto. – user2661923 Dec 05 '20 at 01:21
  • @user2661923 So should I just move on and not worry about it? I mean, I can prove it with limits like this link did but I cannot in the fashion that Apostol did. – sharmello Dec 05 '20 at 02:21
  • "So should I just move on and not worry about it?" Unclear what you are asking. If you are asking whether you need to verify that his analysis is valid, then yes, you do. Alternatively, if you are worrying that your intuition has not stretched to the point where you might have had a chance to originate the analysis, then no you don't need to worry about it. However, intuition stretching is very important. So it is a good idea (besides the formal verification) to intuitively grasp his idea(s). – user2661923 Dec 05 '20 at 02:29
  • @user2661923 Thank you for your quick reply. By moving on from it, I meant that I would just keep progressing with the book if that is what I should do. I can understand how found the area of the parabolic segment of y=x^2 between x = 0 and x = b through limits but in Apostol's version of the proof, he does not use limits. To me, he pulled the n^3/3 from somewhere and I do not know where. Apologies if my math symbols aren't correctly formatted. – sharmello Dec 05 '20 at 02:40
  • I disagree; Apostol is (very informally) using the squeeze theorem of limits. His central idea is that if $f(n) = \frac{(n)(n+1)(2n+1)}{6}$, then $f(n-1) < \frac{n^3}{3} < f(n).$ The right side of the inequality is immediate. For the left side, simply note that $(n-1)n(2n-1) = 2n^3 - 3n^2 + n.$ I recommend that you reread that section. – user2661923 Dec 05 '20 at 02:50
  • @user2661923 Yeah, so if we take the limit of f(n-1) where n approaches infinity, the value we are approaching is b^3/3. If we take the limit of f(n) where n approaches infinity, again the value we are approaching is b^3/3. Hence, we can conclude the area under the parabola of y=x^2 between x = 0 and x= b is b^3/3. Maybe I am not understanding you and apologies if I am not but I am still confused as to where n^3/3 came from. As you suggested previously, the idea may have come from a previous development of calculus that occurred long before Apostol did this proof. – sharmello Dec 05 '20 at 03:06
  • See my answer. If more questions, post the question immediately following my answer, and I will be automatically flagged. – user2661923 Dec 05 '20 at 03:50
In the early 1700's, Bernoulli proved (without Calculus) that for any positive integer $k$, there exists a unique set of rational numbers $c_0, c_1, \cdots, c_k$ such that
for any positive integer $n$, $$\sum_{i=1}^n i^k = c_0n^{(k+1)} + c_1n^k + \cdots + c_kn^1.$$
Actually, Bernoulli took it one step further, and originated the idea of Bernoulli numbers. For the purposes of this discussion, that is irrelevant.
Bernoulli's demonstration is (partially) recreated here.
So, it was well known, for centuries that
$$\sum_{i = 1}^n i^3 = \frac{1}{3}n^3 + \frac{1}{2}n^2 + \frac{1}{6}n.$$
What Apostol is doing in these first few pages is giving you an informal (but valid) glimpse of estimating the area under the curve through a series of step functions (e.g. rectangles). His algebra in the pages that you cited is valid.
Whoever originated the idea that Apostol is merely repeating had the vision that the area of the inner rectangles would always be less than $\frac{b^2}{3}$ but would get closer and closer to $\frac{b^2}{3}.$
The analyis is that the $k$-th rectangle has width $\frac{b}{n}$ and height $\left(\frac{kb}{n}\right)^2.$ Therefore, the $k$-th rectangle has area $\frac{b^3}{n^3}k^2.$
Therefore, the sum of the area of the inner rectangles is
$$\frac{b^3}{n^3} \times \sum_{k=0}^{(n-1)}k^2$$
and the sum of the area of the outer rectangles is
$$\frac{b^3}{n^3} \times \sum_{k=1}^{n}k^2.$$
From the above algebra, it is immediate that as $n \to \infty$, the sum of the area of the inner triangles will converge to $\frac{b^3}{3}$ from below, and the sum of the area of the outer triangles will converge to $\frac{b^3}{3}$ from above.
Therefore, Apostol is (through the informal use of the squeeze theorem of limits) repeating the idea that some Calculus pioneer envisioned: the exact area under the curve has to be $\frac{b^3}{3}.$
What may be confusing is that Apostol's (algebra-only, no Calculus) derivation of the formula for $\sum_{i=1}^n i^3$, on page 6, though valid, is somewhat non-standard. The non-Calculus derivation normally uses induction, as in the mathSE link that I cited.
user2661923
  • 35,619
  • 39
  • Thank you! In addition to your response, I was able to clear up all other questions about this proof with this video and this video. I understand now why the n^3/3 was used. Thank you! – sharmello Dec 05 '20 at 19:31
