I cannot understand how this formula is called and in what cases it is applied. Can you help with this and give examples of equations using these formulas?
Asked
Active
Viewed 30 times
It's a special case of the Polynomial Factor Theorem. – Bill Dubuque Nov 18 '20 at 16:43
$$S = 1 + a + ... + a^{n-1}$$ $$aS = a + a^2 + ... + a^{n}$$ So by subtracting $$(a-1)S = a^n - 1$$ for $n \in \mathbb{N}$
So this is basically just geometric progression! You can derive the second result similarly - i.e. divide LHS and RHS by $(a+1)$ and observe that the sum $(1-a+a^2...-a^{2k-1}+a^{2k})$ is a geometric progression with common ratio $=-a$. Doing a manipulation similar to what I did above with $S$ will lead you to the result.
Examples of where these are used? Well, it's always nice to have some factorization tricks up your sleeve.
stoic-santiago
- 13,705
