So I figured of a way to map any infinite sequence of (infinitely many non-zero) integers to $2$ numbers. Let the sequence be,
$$ f(1), f(2),f(3),\dots$$
Now, we construct the following:
$$ S =e^{- f(1) \delta} + e^{- f(2) \delta} + e^{- f(3) \delta} + \dots $$
Let us assume, the below converges to a number $c \neq 0$:
$$ c = \lim_{\delta \to 0} S \delta =\lim_{\delta \to 0} (e^{- f(1) \delta} + e^{- f(2) \delta} + e^{- f(3) \delta} + \dots) \delta $$
(This can be calculated using this with $f = e^{-x}$ and $k = \infty$)*. Then, our numbers are $c$ and the $1$ since we raised the $S$ to the power $1$. Let us, now assume the series converges to $0$ or diverges in that case raise the original series to the power $\lambda$. Such that it converges to $c \neq 0 \neq \infty$. Then we have:
$$ c = \lim_{\delta \to 0} S^\lambda \delta =\lim_{\delta \to 0} (e^{- f(1) \delta} + e^{- f(2) \delta} + e^{- f(3) \delta} + \dots)^\lambda \delta $$
Hence, any integer series can be (one-to-many) mapped to $2$ numbers $(c,\lambda)$ where $c$ tells you the type of function and $\lambda$ tells you the density.
Question
Will this scheme always work? Are there any other mappings between an infinite integer sequence and two real numbers which accomplish the same? Is there a nice way to see the inverse mapping and see it's sensitivity to say $(c,\lambda) \to (c + \epsilon, \lambda)$ or $(c,\lambda) \to (c, \lambda + \epsilon)$?
