Consider the equation:
$f(a+b,\lambda) = f (a,\lambda) \cdot f(b,\lambda)$, for $a \geq 0$ and $b \geq 0$.
Is my understanding that this simple functional equation is important in analysis. Can someone give me examples where this can be used in practice, its theoretical importance and maybe some literature where I can find more?
Also, if $f(\cdot,\lambda)$ is continuous, then one can show that $f(a,\lambda) =$exp$(ag(\lambda))$, for some function $g(\lambda)$. Is this the only type of function that will satisfy the equation above?
MJD
  • 65,394
  • 39
  • 298
  • 580
Cherufe
  • 110
