I am trying to evaluate the following integral using the saddle point method:
\begin{equation} \int_0^\infty \exp\left\{-N\left(\frac{\epsilon}{\sigma}+\ln (\sigma+1)+\frac{y^{2}}{\sigma+1-\tau}+\frac{\left(a^2+x^2\right)}{\sigma +\tau +1}\right)+\ln\left[2\cosh \left(\frac{2 a N x}{\sigma +\tau +1}\right)\right]\right\}\mathrm{d}\sigma \end{equation}
The problem I have is that I do not have the form: \begin{equation} \int_0^\infty e^{-Nf(\sigma)}\mathrm{d}\sigma \end{equation}
where $f(\sigma)$ is independent of $N$ due to this term: $$\ln\left[2\cosh \left(\frac{2 a N x}{\sigma +\tau +1}\right)\right]$$ $\implies$ Is there a way to extract the $N$? Or modify the term to some approximation?
$\implies$ Is there any other way to evaluate this integral?
If I missed to provide some important details or context, please let me know and I will edit the question.
where $\sigma^*$ is the unique positive solution to the equation $-4a^2 \sigma^2(\sigma+1)-\epsilon (\sigma+1)(\sigma+\tau+1)^2+(\sigma+\tau+1)^2\sigma^2=0 $
and $$ \mathcal{F}(\sigma)=\frac{4a^2}{(\sigma+\tau+1)^2}+\log(\sigma+1)+\frac{\epsilon}{\sigma} $$
– asgeige Nov 13 '20 at 22:04I think my reasoning caries over to your more general case as long as the parameters stay postive (maybe $1>\tau>0$ is additionaly required since the term $\sim y^2$ could change its charcteristic radically otherwise, but this is up to you to figure out) .
– asgeige Nov 13 '20 at 22:08
